Bug fixed. You can try it.HakanSeven12 wrote: ↑Sat Jun 20, 2020 9:07 am But there is some bug at pivy trackers so maybe you need to wait untill this PR merged.
https://github.com/joelgraff/pivy_trackers/pull/22
Importing rcs-data from drone scan
- HakanSeven12
Re: Importing rcs-data from drone scan
Support me: Hakan Seven on Patreon
Modern UI: Modern UI on FreeCAD Forum
Trails Workbench: Trails Workbench on FreeCAD Forum
Thanks.
Just downloaded trails-wb, pivy-tracker, freecad python support from github (maybe too early?)
I have copied pivy-tracker/FC-python support files into the empty Trails subfolder. I hope this was right,
see my folder structure below (I am not a coder, forgive me...)
After restart FC Trails wont load, giving back this:
During initialization the error "module 'pivy.coin' has no attribute 'SoGeoCoordinate'" occurred in freecad.trails
File "<string>", line 148, in InitApplications
File "importlib\__init__.py", line 126, in import_module
File "<frozen importlib._bootstrap>", line 994, in _gcd_import
File "<frozen importlib._bootstrap>", line 971, in _find_and_load
File "<frozen importlib._bootstrap>", line 955, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 665, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 678, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "C:\Users\thomas.schrader\AppData\Roaming\FreeCAD\Mod\Trails\freecad\trails\__init__.py", line 53, in <module>
'pivy_trackers.pivy_trackers.tracker.context_tracker', 'ContextTracker')
File "C:\Users\thomas.schrader\AppData\Roaming\FreeCAD\Mod\Trails\freecad\trails\__init__.py", line 50, in import_class
return getattr(import_module(path, name), name)
File "C:\Users\thomas.schrader\AppData\Roaming\FreeCAD\Mod\Trails\freecad\trails\__init__.py", line 43, in import_module
return __import__(path, globals(), locals(), _name_list)
File "C:\Users\thomas.schrader\AppData\Roaming\FreeCAD\Mod\Trails\pivy_trackers\pivy_trackers\tracker\context_tracker.py", line 27, in <module>
from ..trait.base import Base
File "C:\Users\thomas.schrader\AppData\Roaming\FreeCAD\Mod\Trails\pivy_trackers\pivy_trackers\trait\base.py", line 26, in <module>
from ..coin.coin_enums import NodeTypes as Nodes
File "C:\Users\thomas.schrader\AppData\Roaming\FreeCAD\Mod\Trails\pivy_trackers\pivy_trackers\coin\coin_enums.py", line 332, in <module>
class NodeTypes(Const):
File "C:\Users\thomas.schrader\AppData\Roaming\FreeCAD\Mod\Trails\pivy_trackers\pivy_trackers\coin\coin_enums.py", line 342, in NodeTypes
GEO_COORDINATE = coin.SoGeoCoordinate
AttributeError: module 'pivy.coin' has no attribute 'SoGeoCoordinate'
My system:
OS: Windows 10 (10.0)
Version: 0.19.20980 (Git)
Hash: c2818d9159385d23b182dc7167af2d4bacbee94c
Python version: 3.6.8
Qt version: 5.12.1
- HakanSeven12
Your file path seems correct. I don't have this bug. Are you using LP or Conda version?
My system:
My system:
Version: 0.19.21718 (Git)
Hash: 002e25b5617f2c79f65968f1f82f7267899965c3
Python version: 3.8.2
Qt version: 5.12.5
OCC version: 7.4.0
Locale: Turkish/Turkey (tr_TR)
I use the LP version.
the cfdof-wb (the dependencies-checker in Edit/Preferences/CFD gives a gmsh-error).
At the moment I will remain on my version above.
Last weekend I tried the newest dev-snapshot, but the 0.19_21673 has an error inthe cfdof-wb (the dependencies-checker in Edit/Preferences/CFD gives a gmsh-error).
- HakanSeven12
Can you try conda version?
Just tried
Version: 0.19.21673 (Git)
Hash: e1cfaf129866b3482bf8650e8993089a834747f0
Qt version: 5.12.1
Gives back:
OS: Windows 10 (10.0)Word size of OS: 64-bit
Qt version: 5.12.1
Gives back:
- HakanSeven12
Its LP version try conda.
Done.
Trails loaded. This is what I see with
Qt version: 5.12.5
OCC version: 7.4.0
Locale: German/Germany (de_DE) error-message:
C:\GA-NT\Anwendungen\TS_513538\FreeCAD\FreeCAD_0.19.21718-Win-Conda_vc14.x-x86_64\bin\lib\site-packages\mpmath\ctx_mp_python.py:892: SyntaxWarning: "is" with a literal. Did you mean "=="?
if other is 0:
C:\GA-NT\Anwendungen\TS_513538\FreeCAD\FreeCAD_0.19.21718-Win-Conda_vc14.x-x86_64\bin\lib\site-packages\mpmath\ctx_mp_python.py:986: SyntaxWarning: "is" with a literal. Did you mean "=="?
if other is 0:
- HakanSeven12
It's not important. Everything is fine.
