?BUG 0.19 opening file that includes BIM building object results in 'NameError: name 'FreeCADGui' is not defined'
duncandoo
Postby duncandoo » Thu Jun 18, 2020 6:14 pm
To recreate:
1. open FreeCAD, open a new file, switch to BIM workbench
2.create a building object, save file and close
3. reopen test file
4. error appears.
I have made the error go away by adding import FreeCADGui to either line 28 or 131 of BimViews.py. I'm not sure which is preferable, whether this might have some undesirable effect elsewhere, or whether the reference to FreeCADGui on line 152 is necessary at all?
Any advice on best solution gratefully received.
Version:
OS: macOS High Sierra (10.13)
Version: 0.19.21514 (Git)
Hash: 89ddab33f692a9bd739171689f9ab0eb58d64b35
Python version: 3.8.2
Qt version: 5.12.5
OCC version: 7.4.0
Locale: C/Default (C)
Console display:
Python 3.8.3 | packaged by conda-forge | (default, Jun 1 2020, 17:26:49)
[Clang 9.0.1 ] on darwin
Type 'help', 'copyright', 'credits' or 'license' for more information.
>>> Gui.runCommand('Std_Workbench',20)
>>> Gui.runCommand('Std_ViewStatusBar',1)
>>> MRU="0"
>>> exec(open('/Applications/FreeCAD.app/Contents/Resources/share/Mod/Start/StartPage/LoadMRU.py').read())
>>> FreeCAD.openDocument('/Users/duncan/test.FCStd')
>>> # App.setActiveDocument("test")
>>> # App.ActiveDocument=App.getDocument("test")
>>> # Gui.ActiveDocument=Gui.getDocument("test")
>>> Gui.runCommand('Std_OrthographicCamera',1)
>>> Gui.runCommand('Std_About',0)
File "/Users/duncan/Library/Preferences/FreeCAD/Mod/BIM/BimViews.py", line 153, in update
if obj in FreeCADGui.Selection.getSelection():
TheMarkster
Re: ?BUG 0.19 opening file that includes BIM building object results in 'NameError: name 'FreeCADGui' is not defined'
Postby TheMarkster » Thu Jun 18, 2020 8:47 pm
Open that file and change the line at the top from:
import FreeCAD
to
import FreeCAD, FreeCADGui
and see if that fixes it. (You will need to restart FreeCAD to test it.)
My FreeCAD video series on youtube: https://www.youtube.com/c/mwganson
carlopav
Postby carlopav » Thu Jun 18, 2020 8:55 pm
Ping myself to remember to fix it!
vocx
Postby vocx » Thu Jun 18, 2020 9:00 pm
I have made the error go away by adding import FreeCADGui ...
Importing FreeCADGui is indeed the solution, as TheMarkster says.
However, please notice that BIM is an external workbench and it is constantly in development, so you should update BIM regularly to make sure you are using the latest version. It's possible this error will be corrected quickly when the developer notices it.
