Visibility toggle not working after CheckGeometry
Postby chrisb » Sat Jun 20, 2020 9:05 am
After having checked an object with Part->CheckGeometry the space does no longer toggle the visibility
How to reproduce:
- New document
- switch to PartWorkbench
- create a Part cube, leave the defaults
- select the cube and run CheckGeometry with BOPCheck
- close the check panel
- select the cube, hit space -> nothing happens
Further observations
- it is ok on Ubuntu
- the error does not occur in 0.18
- the error does not occur in 0.19.17798 (Git)
- the error does not occur if an error is found.
- the error does not occur without BOPCheck enabled
- the error is not very recent, but I could not really track it until now.
Can other Mac users please confirm?
Can Windows users please try to reproduce?
Ubuntu works here, but others may test it anyway.
OS: macOS High Sierra (10.13)
Version: 0.19.21671 (Git)
Hash: f05253f882b336f56aae32593faa5676fd5aafdd
Python version: 3.8.2
Qt version: 5.12.5
OCC version: 7.4.0
Locale: C/Default (C)
fc_tofu
Re: Visibility toggle not working after CheckGeometry
Postby fc_tofu » Sat Jun 20, 2020 9:13 am
I found the error in recent builds, but cannot reproduce it for now.
OS: Windows 10 (10.0)
Version: 0.19.21514 (Git)
Hash: 89ddab33f692a9bd739171689f9ab0eb58d64b35
Qt version: 5.12.5
OCC version: 7.4.0
Site Admin
Postby wmayer » Sat Jun 20, 2020 1:30 pm
Tested with:
OS: Ubuntu 18.04.4 LTS (XFCE/xubuntu)
Version: 0.19.21715 (Git)
Build type: Debug
Hash: 0d05fc328d7784f2763ec223c9f943038514629d
Python version: 3.6.9
Qt version: 5.9.5
I can't reproduce it neither under Ubuntu nor Windows 10.
Site Admin
Postby wmayer » Sat Jun 20, 2020 1:47 pm
What you can try to do is to check which widgets receive key events by using an event filter:
from PySide2 import QtCore
class MyEventFilter(QtCore.QObject):
  def eventFilter(self, obj, ev):
    if ev.type() == QtCore.QEvent.KeyPress:
      print("Pressed: '{}' {}".format(ev.text(), obj.metaObject().className()))
    if ev.type() == QtCore.QEvent.KeyRelease:
      print("Release: '{}' {}".format(ev.text(), obj.metaObject().className()))
    return False
filter = MyEventFilter()
app = QtCore.QCoreApplication.instance()
app.installEventFilter(filter)
This observes any key press/release events and prints the class names of the recipients.
Postby chrisb » Sat Jun 20, 2020 3:13 pm
I ran the code in the Python console just before selecting the cube. This is the result from Report view (first line is the last from the code):
>>> # Gui.Selection.addSelection('Unnamed1','Box')
>>> Gui.runCommand('Part_CheckGeometry',0)
>>> # Gui.Selection.clearSelection()
After that I hit (three times) the space bar without any response in the Report view. Space bar seems to be dropped.
I changed the width of the cube entering "12 cm" including the space. It was visible in the input field but without echo in the Python console. Only numbers enteres and a complete unit where echoed.
mario52
Postby mario52 » Sat Jun 20, 2020 3:24 pm
hi
no problem
Version: 0.19.21673 (Git)
Hash: e1cfaf129866b3482bf8650e8993089a834747f0
Python version: 3.6.8
Qt version: 5.12.1
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Topological_data_scripting, Dialog creation. My macros on Gist.github.
Site Admin
Postby wmayer » Sat Jun 20, 2020 3:27 pm
You must enable the Python redirection in the preferences because otherwise the messages are swallowed.
Postby chrisb » Sat Jun 20, 2020 4:01 pm
:oops:
- Cleared the Report view
- selected the Cube
- invoked CheckGeometry with BOPCheck
- closed the CheckGeometry panel
- selected Cube again
- up to this moment no output in Report view
- hit spacebar yields in Report view
Pressed: ' ' QWidgetWindow
Pressed: ' ' Gui::TreeWidget
Release: ' ' QWidgetWindow
Release: ' ' Gui::TreeWidget
Release: ' ' Gui::TreePanel
Release: ' ' QSplitter
Release: ' ' QStackedWidget
Release: ' ' QTabWidget
Release: ' ' Gui::DockWnd::ComboView
Release: ' ' QDockWidget
Release: ' ' Gui::MainWindow
If I switch to another application (e.g. the browser) and back, the spacebar behaviour returns to normal.
Output in Report view is then
Postby chrisb » Sat Jun 20, 2020 4:07 pm
Perhaps the source of the troubles is not the key but rather the selection. If I select after the BOPCheck the cube it properly shows the properties in the Data tab. But in the TreeView the selection is only light blue:
Snip macro screenshot-cb2435.png (3.58 KiB) Viewed 275 times
After switching to the browser and back it is dark blue:
Snip macro screenshot-6efc80.png (3.54 KiB) Viewed 275 times
Site Admin
Postby wmayer » Sat Jun 20, 2020 5:32 pm
When I run the check geometry function then the selection is cleared. So, maybe on your system it's not properly cleared. When click on an empty space in the tree to make sure it's cleared and then select the box again does the visibility toggle work then?
