Ticket #4384 - Formula editor not active window when invoked
martin51
Postby martin51 » Thu Jun 25, 2020 6:25 am
Clicking on the formula editor button when defining a constraint calls the formula editor window to the front but the text entry box is not active until clicked in. As shown in the screen shot the constraint editor behind the formula editor is the active window so any keyboard input lands in the constraint editor not the formula editor.
Screen Shot 2020-06-24 at 11.05.17 PM.png (84.34 KiB) Viewed 139 times
Normally in MacOS any window that is brought to the front becomes the active window so remembering to click in the text entry box or selecting and deleting existing text which is already highlighted rather than immediately entering text is a hard habit to break. It's also odd that the formula editor windows in Constraint and Pad behave differently. In the Constraint Formula editor previously entered text is selected but not active whereas in the Pad formula editor the default text has to be selected before it can be replaced.
Screen Shot 2020-06-24 at 11.06.10 PM.png (81.93 KiB) Viewed 139 times
Maybe I'm just too old a dog to learn a new trick, but is there a simple fix that would make the formula editor windows active with any previous entry selected so that it will be replaced without having to click and/or select?
Thanks as always for help and comments.
OS: macOS 10.15
Version: 0.19.21718 (Git)
Hash: 002e25b5617f2c79f65968f1f82f7267899965c3
Python version: 3.8.2
Qt version: 5.12.5
OCC version: 7.4.0
Locale: C/Default (C)
FormulaEditor.FCStd
(9.65 KiB) Downloaded 1 time
Reason: Added ticket number to thread title
Re: Formula editor not active window when invoked
Postby chrisb » Thu Jun 25, 2020 7:53 am
This is a known issue on MacOS, but I'm not sure if a ticket exists. Please check the tracker and create a ticket if none exists. Cross link it to this topic.
I may add that it works correctly if called from the DataTab. The problem possibly arises due to the double dialog.
martin51
Postby martin51 » Thu Jun 25, 2020 5:31 pm
Couldn't find anything in tracker. Have created new ticket # 0004384
Postby chrisb » Thu Jun 25, 2020 7:38 pm
Thanks. For the next time: you can use the bug tag which creates a link directly:
[bug]4384[/bug]
this yields: issue #4384.
tom
Re: Ticket #4384 - Formula editor not active window when invoked
Postby tom » Sat Jul 11, 2020 9:07 pm
