3D Printed Model has blemish
Reynard1066
Re: 3D Printed Model has blemish
Postby Reynard1066 » Mon Jul 06, 2020 10:53 am
I create a B-Spline model in Blender and exported as an STL. Excellent mesh and consistent triangle size at a given height.
Imported into FC and created a solid from the mesh, then a base feature. I tried to pocket the base but FC wasn't having it. More FC mysteries I have yet to learn.
Image 3.png (75.29 KiB) Viewed 155 times
TomB19
Postby TomB19 » Mon Jul 06, 2020 1:17 pm
abasel wrote:
Sun Jul 05, 2020 10:17 pm
I also changed Maximum Mesh Deviation to 1umm and the blemish was reduce to an unnoticeable size. Large file but good result :)
May I ask where this is configured? I can't find it in pre-0.19.
Reynard1066
Postby Reynard1066 » Mon Jul 06, 2020 1:30 pm
Select the Mesh Design workbench.
Edit->Preferences.
Import-Export, select Mesh Formats tab, Export group box.
drmacro
Postby drmacro » Mon Jul 06, 2020 1:34 pm
Without the stl and maybe the FreeCAD file for others to look at...it will probably remain a mystery... 8-)
My beginners, written treatise: Learning FreeCAD
Reynard1066
Postby Reynard1066 » Mon Jul 06, 2020 2:06 pm
The FC file is some 17Mb.
Attached is the STL file from Blender.
Skittle.stl
(800.08 KiB) Downloaded 2 times
drmacro
Postby drmacro » Mon Jul 06, 2020 3:32 pm
Import into Blender and it says there are 128 non-manifold edges and 128 non-manifold verts.
And all the polygon normals are reversed. (pointing inward)
This wold be expected to fail, but:
In FreeCAD I had to set the tolerance lower than .1 to convert mesh to shape.
Afterwards there are a large number of self intersecting faces & edges according to Check Geometry.
After correction in Blender it seems fine:
Reynard1066
Postby Reynard1066 » Mon Jul 06, 2020 4:36 pm
Hi drmarco,
Thank you for looking at this. You are correct the normals are all pointing inwards. I have done a recalculate to outside and will try again.
I am a bit concerned that there may be a very small hole in the top centre that didn't close during the 360 spin. To be checked out.
Again thank you for the pointer. Still a bit of a noob with FC.
Reynard
drmacro
Postby drmacro » Mon Jul 06, 2020 4:58 pm
Hi drmarco,
Reynard
There was one in the top and the bottom, that is the source of the non-manifold.
abasel
Postby abasel » Mon Jul 06, 2020 9:35 pm
For export there is a setting from Mesh Design WB
Edit > Preferences > Import-Export > Mesh Formats tab > "Maximum mesh deviation"
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
Locale: English/NewZealand (en_NZ)
