Center mark in a technical drawing
niceandeasy
Post by niceandeasy »
Is there a way to create a center mark in a technical drawing (red lines) ?
Another question: does the Tech Draw module replace the Drawing module ?
(I am using version 0.19 for Windows)
Thank you beforehand
Re: Center mark in a technical drawing
Please have a look at the documentation of TechDraw Workbench. There is a property ArcCenterMarks which can be set to true.
niceandeasy
Thank you for the reply. I have have tried changing that property to TRUE but no change was noticed. Please see attached file
Peça 3 versão 0.19 V2.FCStd
(59.99 KiB) Downloaded 56 times
drmacro
Post by drmacro »
niceandeasy wrote: Fri Jul 03, 2020 4:24 pm Thank you for the reply. I have have tried changing that property to TRUE but no change was noticed. Please see attached file
In Edit>Preferences>TechDraw >Annotation
Set Show center marks to see centermarks when frames are on.
Set Print Center Marks to see them when frames are off.
M4x
Post by M4x »
Try to refresh the page.
niceandeasy
Thank you for the replies, tomorrow I will try again and will post the results :)
Regards
Accessdenied
Post by Accessdenied »
Thanks, this helped to me also. But how to change center mark line style?
mendy
Post by mendy »
Could try this: Macro has nice features and was just recently updated.
Note: To remove a line click on it and then on eraser icon (Remove Cosmetic Object) in toolbar.
Can also click on line then change line style.
https://forum.freecadweb.org/viewtopic.php?f=35&t=55029
drmacro
Post by drmacro »
You can use the centerline tool in TechDraw workbench.
orionrobots
Post by orionrobots »
Note for future users - if you turn on center marks - note that this is a preference in italics. That means you will need to re-insert the projection for the drawing for this change to apply to it.
Thanks for this discussion - it helped me out!
