3Dsurface: where is direction of cut? NOT fixed
freman
Postby freman » Fri Jul 03, 2020 8:45 pm
HI,
I have been using 3D-surface thoughout its evolution but it seems that the means to set direction of cut has gone ( or been made obscure in some way ).
There used to be X or Y direction in the UI. Then this became redundant and there was some angle setting which had to be set in tree view.
Now I don't seem to find it anywhere. I remember struggling to find it last time , so maybe I've just forgotten, but I don't see any kind of angle setting.
Could someone point out where this can be done?
TIA.
OS: Fedora 31 (Thirty One) (LXDE/LXDE)
Version: 0.19.21806 (Git)
Hash: 68b98f5ffead8d90b2e9f6308ca55acefd758352
Python version: 3.7.7
Qt version: 5.13.2
sliptonic
Re: 3Dsurface: where is direction of cut?
Postby sliptonic » Fri Jul 03, 2020 8:49 pm
There's 'cut pattern angle' available if you have cut pattern set to zigzag or line.
freman
Postby freman » Fri Jul 03, 2020 9:00 pm
Many thanks, don't know why I couldn't see it.
freman
Re: 3Dsurface: where is direction of cut? FIXED
Postby freman » Sat Jul 04, 2020 12:03 pm
Oops, not so fast.
The reason I could not see it is because it was not there !
At one point this a.m. I found one of the two 3Dsurface ops on this job had the angle param visible the other not. ;)
I was going to point the FCStd but FC crashed, and when I reopened both were open , so not much help. It seems to be a transitory bug.
I'm guessing that since visibility gets flipped depending up on the kind of path ( line or zigzag vs the rest ) , sometimes visibility of this param is not getting set correctly.
GeneFC
Re: 3Dsurface: where is direction of cut? NOT fixed
Postby GeneFC » Sat Jul 04, 2020 2:29 pm
Did you try "right click" and "Show All" in the property panel?
I do not understand the logic of which parameters are shown and which are hidden, but "Show All" will make everything visible.
Gene
freman
Postby freman » Sat Jul 04, 2020 2:53 pm
thanks for that tip Gene, but the point of posting was to make the bug known and hopefully get it fixed.
I now understand why sometimes I spend ages going back and forth trying to find what I need to set and can't find it. I thought I was having a senior moment. Unless this little glitch gets fixed , I won't be the last.
It seems that maybe closing and reopening may fix it too, but it does need fixing.
That should be trivial now it's been pointed out.
