Why does this invert?
Even the Navigation cube "REAR" is upside down. It makes it difficult to mentally track where I need to put stuff.
Basic Sketch attached.
Open Sketch1 click "set to isometric view" and that's my Front with the big hole at the top.
Now, I want to do some work on the Rear.
I rotate it around and click the Rear and it changes color.
I click "Create a new sketch" and it turns it upside down. See Sketch2.
That is a mental challenge with a complex part to try and get my head wrapped around to now work upside down.
Is this a setting I have wrong? What, Where and how to change it?
OS: Linux Mint 19.3 (X-Cinnamon/cinnamon)
Version: 0.19.21775 (Git) AppImage
Python version: 3.8.2
Qt version: 5.12.5
OCC version: 7.4.0
Qt version: 5.12.5
OCC version: 7.4.0
- Gregory son of Carl
Re: Why does this invert?
You can change your sketch view orientation by adjusting the Map Mode settings in the Properties window for any sketch. To flip the Rear sketch around, change the z-axis angle to 180 degrees.
It is ill advised to attach sketches to solid geometry, rather use std planes, sketches or properly attached data planes.
See Topological_naming_problem.
There are a number of workflows that can help, see Sketcher_ViewSection or Std_DrawStyle
Thanks, that kinda works, but as soon as I close Sketcher it turns everything back to to front face and a "Pad" then pops the addition out the back. I need to forever rotate the thing to the Rear to see what I just added.Gregory son of Carl wrote: ↑Sat Jul 04, 2020 2:32 am You can change your sketch view orientation by adjusting the Map Mode settings in the Properties window for any sketch. To flip the Rear sketch around, change the z-axis angle to 180 degrees.
If I am doing it wrong, is there a video showing how it should be done?
The Sketcher View Section kinda works but then I still have to rotate thing around to the Rear in order to attach a new item like a Hex etc.
If I use "Create an edge linked to external geometry," to locate the big hole, select "Hex," the cursor never turns to the Cross to attach it. I have to rotate the view to the Rear and then it gives me the cross when over the center.
As I asked Gregory above, if I am doing it wrong then is there a video to show how a part should be modeled. I have been doing the ""ill advised" way with earlier versions for years. Up until a few versions back it was working as I expected. I will go back through old the older .appimage of v19 and see if I can regain that old process as his new one sucks big time. One step forward, 28-back.
I'd really prefer to be doing it the "advised" way but so far it is not making sense to me. Maybe I am overly dense, but the "it should not be this hard," poster seems to be equally at a loss too.
One thing I'd ask: why do you have your Body in a Part? This is not required.MikeDewitt wrote: ↑Sat Jul 04, 2020 5:15 pmThe Sketcher View Section kinda works but then I still have to rotate thing around to the Rear in order to attach a new item like a Hex etc.
Also, with that gone and the axis planes turned on it looks ok. The Pad was done on along the Y axis as expected...
- orientation.png (150.58 KiB) Viewed 1371 times
V0.17, V0.18 and V0.19 all show the behavior described your OP.MikeDewitt wrote: ↑Sat Jul 04, 2020 5:15 pm Up until a few versions back it was working as I expected.
@kisolre tries to explain things here: https://forum.freecadweb.org/viewtopic. ... 75#p410991.
After exiting a sketch, the model view should automatically return to the last view you were in before entering the sketch. If you rotate the model before entering the sketch then you should be able to avoid that hassle. You can also turn off this behavior by going to Edit> Preferences> Sketcher (WB)> Display (Tab)> Restore Camera Position after Editing.MikeDewitt wrote: ↑Sat Jul 04, 2020 5:05 pm Thanks, that kinda works, but as soon as I close Sketcher it turns everything back to to front face and a "Pad" then pops the addition out the back. I need to forever rotate the thing to the Rear to see what I just added.
Doing things the "right way" is mostly about improving long term model stability. If the part is a one-off that you'll never return to then don't worry too much about best practices. Just do whatever is the quickest and most intuitive.
