Creating repeated holes through a sphere
abasel
Postby abasel » Sun Jul 05, 2020 10:51 pm
What is the approach that I should follow to punch a series of shaped holes through a sphere e.g. trying to achieve the top part of this rattle.
Reynard1066
Re: Creating repeated holes through a sphere
Postby Reynard1066 » Mon Jul 06, 2020 1:24 pm
Set up a few Datum Planes at the correct place and angle.
Draw sketches of the apertures and pocket through the hollow hemisphere.
A polar pattern for each pocket.
Add in some guessing for hole shape and position.
Rattle Top.png (53.46 KiB) Viewed 184 times
abasel
Postby abasel » Mon Jul 06, 2020 9:37 pm
Awesome, thanks :)
abasel
Postby abasel » Mon Jul 06, 2020 10:36 pm
I am battling to place the Datum planes. Could you please give me a screenshot of your Plane Parameter settings so that I can compare?
I tried adding a datum plane and then move it 40mm along the y-axis but nothing happens
Rattle.FCStd
(8.49 KiB) Downloaded 2 times
vocx
Postby vocx » Tue Jul 07, 2020 3:35 am
The coordinates are local to the attachment, so you may have to move the X or Z coordinates instead of the Y coordinate.
Reynard1066
Postby Reynard1066 » Tue Jul 07, 2020 7:57 am
Yes datum planes do seem like trial and error to see which way they move, but you work something out eventually.
I have been struggling to get the file size below the 1Mb mark. Using compression level 9 seemed to do it.
File attached.
Rattle Top.FCStd
(982.14 KiB) Not downloaded yet
