I'm having issues with hole directions. When I wasn't following best practice and sketching on object faces I had no real problems, now I'm sketching on offset datum planes I sometimes have an issue with holes. This is using the Part Design workbench.
If I draw a sketch and pocket, sometimes I need to reverse direction to get the pocket to go in the right direction. If I use the 'Hole' facility there is no option to reverse the hole.
I've just spent a few minutes with a cube trying to draw on the 'upper' face of a datum plane and the 'lower' face.The sketch simply re orientates, the sketch ends up effectively the same and the hole can't be produced. Sometimes it seems I get it right, sometimes I don't.
This is basic stuff and having used Freecad for a few months now I should be able to sort this out, but it seems I've got a logic gap somewhere. Can somebody point the obvious out to me please.
Many thanks,
Jeff
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
[Solved] - Datum Planes - Reversed Hole Direction
Re: Datum Planes - Reversed Hole Direction
As QUEEN would say, "Its a kind of magic".
Both Pocket and Datum Plane dialog boxes have a reverse check box in them. Experiment with them.
Reynard
Reynard
Try to provide a file, a simple case explaining the problem is adequate.
Edit the plane and set map reversed to true, see if that does the trick?
[Solved] - Re: Datum Planes - Reversed Hole Direction
Thank you Bance/Reynard1066,
There is no 'Hole Direction' option that I can see in the 'Hole Parameters' configuration tab, but having first produced the hole I found the option to reverse the direction under the 'Property' tab.... I should have looked there first.
Would it be a sensible addition to the 'Parameters' tab, if not already in 0.19?
Cheers,
Jeff
Cheers,
Jeff
Re: [Solved] - Datum Planes - Reversed Hole Direction
Ahhhh! That Hole. I was thinking pocket.
Yes, a reverse check box would be nice to have.
Since we are on the subject of Plane direction, something that confuses me is that if I create a datum plane on the XZ world plane I would expect the datum plane normal (Z) to follow the remaining world (Y) but it does the opposite. There is probably a very good reason for this, like "it's too late to change it now".
Also for those using datum planes: a pad follows the direction of the normal (local Z), a pocket (or hole) goes in the opposite direction.
This has been discussed before, for XZ the normal is -Y, for ZX the normal is +Y.Reynard1066 wrote: ↑Tue Jul 07, 2020 2:50 pm if I create a datum plane on the XZ world plane I would expect the datum plane normal (Z) to follow the remaining world (Y) but it does the opposite.
