image import
image import
hi all I am new to FreeCAD and I have a picture (jpeg) of the letter S I need to import it into FreeCAD and copy it so I can print a 3d design of this. My problem is I have tried everything but the image does not show in the program so I can't trace it to a 3d image. Please can someone talk me through this. it can't be hard can it? Thanks
Re: image import
Welcome to the forum!
Did you try to search for the solution? Did you read the red banner at the top of this page?
Re: image import
Use the Image_CreateImagePlane command.
Re: image import
Image import? When I load a image jpeg using create planer image tool it looks like its downloaded the image but I cant see it why? I am new to CAD drawing and would love to learn. My first task is to take a image (jpeg) load it into Freecad then trace it and make a 3d model on my 3d printer. Sounds easy enough but having trouble just downloading the picture and seeing it to trace! I have looked every were for a tutorial on this but the only one I can find is on youtube with a older version of FreeCAD, Please can somone help! Thanks
Re: image import
Try this one:
https://www.youtube.com/watch?v=xorYJELqTxw
Re: image import
Note that for the outline of TTF letters you should first look at the Draft_ShapeString command.
Re: image import
Please read the link in the banner, read again, then attach here your JPEG picture as well as your FreeCAD file where you tried to import it.minimadmalc wrote: ↑Thu Jul 09, 2020 8:36 am Image import? When I load a image jpeg using create planer image tool it looks like its downloaded the image but I cant see it why? I am new to CAD drawing and would love to learn. My first task is to take a image (jpeg) load it into Freecad then trace it and make a 3d model on my 3d printer. Sounds easy enough but having trouble just downloading the picture and seeing it to trace! I have looked every were for a tutorial on this but the only one I can find is on youtube with a older version of FreeCAD, Please can somone help! Thanks
Re: image import
It could be a driver issue if you're on Windows using 0.18.4. This is why it's important to provide the FreeCAD information: help -> about -> copy to clipboard. If this is the case you can update to the latest 0.19 and see if that solves it.
