Flipping Horizontally (Mirroring) A Mesh...
R23D
Postby R23D » Sat Jul 18, 2020 7:01 pm
OS: Windows 7
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
Ok... I give up. How do you mirror a mesh object? I want to create a mirror image of my mesh in the x-y direction. I figure it's such a basic operation and not too mathematically difficult to perform on a mesh that IT MUST BE POSSIBLE... but I'll be damned if I can work out how. It's driving me crazy. :shock: I don't want to have a mirrored copy of the shape, I just want to mirror the original mesh. Any help would be GREATLY appreciated. Thankyou in advance. :)
TheMarkster
Re: Flipping Horizontally (Mirroring) A Mesh...
Postby TheMarkster » Sat Jul 18, 2020 7:14 pm
I don't think this can be done at this time in FreeCAD without converting to Part object, mirroring, and then converting back to mesh. Blender can do it directly, I believe.
My FreeCAD video series on youtube: https://www.youtube.com/c/mwganson
R23D
Postby R23D » Sun Jul 19, 2020 9:23 am
:( Ok, thanks. I will try Blender. At least I feel like less of an idiot now for not being able to work it out. I should really post a feature request because in my opinion it's a little bit crazy that you can't do that... You can do just about anything else.
Postby chrisb » Sun Jul 19, 2020 10:55 am
No, it's not crazy. FreeCAD is a parametric modeler, which uses a completely different internal representation of solids. A Mesh is usually a deterioration, because it lacks precision, yet it has much more surfaces to deal with.
Working with meshes has the main purpose to transform them to or from normal FreeCAD shapes.
Roy_043
Postby Roy_043 » Sun Jul 19, 2020 1:37 pm
IMO this would be a useful feature. The Mesh_Scale command could probably be extended to accept 3 scale factors (X, Y and Z) instead of just one.
ulrich1a
Postby ulrich1a » Sun Jul 19, 2020 4:24 pm
You need to use python, than FreeCAD can do nearly all what you want. ;) There is the workbench OpenSCAD, which uses the program OpenSCAD to do operations with meshes. OpenSCAD does have a mirror operation, see here: https://en.wikibooks.org/wiki/OpenSCAD_ ... ons#mirror
Unfortunatly the mirror operation is not available directly in the OpenSCAD workbench. But after some digging in the python source, there is the command "callopenscadmeshstring", which can be used for this purpose. Here is a script, that can be used as a macro to mirror a FreeCAD mesh.
Just select the mesh and call the macro. I have tested it with a simple cube, where it works as expected. It does not test, if the selected object is a mesh. The mirror operation is done with a plane defined with a normal in x-direction through the origin. The coordinates of the mirror command in the script have to be adopted for other mirror planes.
Ulrich
#!/usr/bin/env python
# -*- coding: utf-8 -*-
import OpenSCADUtils
from exportCSG import mesh2polyhedron
mylist = FreeCAD.Gui.Selection.getSelectionEx()
for o in mylist:
  #print (o.ObjectName)
  #print (o.Object)
  poly = mesh2polyhedron(o.Object.Mesh)
  mi = OpenSCADUtils.callopenscadmeshstring('%s{%s}' % ('mirror([1,0,0])',''.join(poly)))
  mi.flipNormals()
  newMeshObj = d.addObject('Mesh::Feature', 'MirrorMesh')
  newMeshObj.Mesh = mi
TheMarkster
Postby TheMarkster » Sun Jul 19, 2020 4:39 pm
Ulrich
for o in mylist:
  #print (o.Object)
  mi.flipNormals()
Nice find, Ulrich. Minor change (d = App.ActiveDocument):
for o in mylist:
  #print (o.Object)
  mi.flipNormals()
TheMarkster
Postby TheMarkster » Sun Jul 19, 2020 8:56 pm
This PR will add the mirror mesh feature command to OpenSCAD workbench. Also fixes an issue with the refine shape command in that same workbench.
https://github.com/FreeCAD/FreeCAD/pull/3720
Snip macro screenshot-977e72.png (151.13 KiB) Viewed 292 times
Snip macro screenshot-018438.png (158.15 KiB) Viewed 292 times
Snip macro screenshot-aae3d7.png (104.55 KiB) Viewed 292 times
ulrich1a
Postby ulrich1a » Sun Jul 19, 2020 9:24 pm
I had a short look at your pull request. FreeCAD has a paradigm in separating functions and gui operations, in order to allow call functions without the gui. This allows FreeCAD to run in server mode. So can you change your pull request to separate the mirror function from calls to the gui?
Ulrich
TheMarkster
Postby TheMarkster » Sun Jul 19, 2020 9:26 pm
Ulrich
I'll look into it. Thanks.
Edit: PR updated. Please have another look and let me know.
With the update you can now call via python OpenSCADUtils.mirror(msh, vec) where msh is the mesh object and vec is a FreeCAD.Base.Vector. Then if you want to show the new mesh in the tree:
import Mesh
Mesh.show(msh)
Edit2: I renamed mirror() to mirrormesh()
