STEP files
STEP files
I have just started to us FreeCAD for viewing STEP files. Is there a way to create a cross section with these files?
Re: STEP files
There are several ways:
- Part SliceApart
- Part CrossSection in the wiki to be found as Part SectionCross
- Macro "cross section", to be installed via Addon manager
- TechDraw SectionView
- And the manual way: Use a big cube and cut it from the Step object.
- Part SliceApart
Re: STEP files
The Std_ToggleClipPlane command may also work.
Re: STEP files
Thank you for this explanation.
How do I show a section that does not make the thickness of the parts look hollow?
Re: STEP files
Read the Notes paragraph of the Std_ToggleClipPlane documentation.
Re: STEP files
This doesn't appear to do what I want.
I am looking to see the thickness of the walls of the parts appear solid in a section view.
I have set up my preferences to receive emails when someone replies but I'm not getting any. What should I be doing?
Re: STEP files
Did you subscribe to the topic?
Re: STEP files
You should be a little clearer about what you are doing. You have received several suggestions. So I am clueless as to what you mean by 'this'.
If you are talking about the Std_ToggleClipPlane command:
Note that you can choose black for the Backlight color. Which should give the illusion of a solid object (provided there is only one clipping plane).
Re: STEP files
If one of the methods mentioned doesn't match your desires, you should try another. Did you try all the methods mentioned above?
chrisb wrote: ↑Mon Jul 20, 2020 4:39 pm There are several ways:
- Part SliceApart
Re: STEP files
Before I try any of the suggestions I need to make sure you understand what it is I'm trying to achieve. I have attached a jpeg file showing two images. A is what I get when using Clipping plane. B is what I'm trying to achieve.
Does this help?
Does this help?
