Spreadsheet: set true/false property in model data
drmacro
Postby drmacro » Fri Aug 07, 2020 2:54 pm
In the properties data tab the little blue fx icon allows you to get the value from the spreadsheet.
But, some properties are true/false and give a control that allows the user to select true or false.
Is there a way to set this property from a spread sheet?
My beginners, written treatise: Learning FreeCAD
openBrain
Re: Spreadsheet: set true/false property in model data
Postby openBrain » Fri Aug 07, 2020 5:13 pm
AFAIK boolean properties aren't expression aware, thus can't be directly bound to a spreadsheet value.
You can do that with a macro, but it will be neither saved in the document nor working on another installation.
drmacro
Postby drmacro » Fri Aug 07, 2020 6:45 pm
I suspected as much.
Roy_043
Postby Roy_043 » Fri Aug 07, 2020 7:01 pm
Something like this works:
App.ActiveDocument.Box.setExpression('MapReversed', u'Spreadsheet.MyBool')
drmacro
Postby drmacro » Fri Aug 07, 2020 7:06 pm
Just to be sure I understand...which can always be questionable. :D
That code would need to be run each time the spreadsheet cell was changed, correct?
Roy_043
Postby Roy_043 » Fri Aug 07, 2020 7:08 pm
Try it!
openBrain
Postby openBrain » Fri Aug 07, 2020 7:12 pm
Nope. 'setExpression' sets an expression binding inside the expression engine, which will be updated on recompute automatically. ;)
I hadn't expected this to be possible. Thx Roy, will try it also. :+1:
drmacro
Postby drmacro » Tue Aug 11, 2020 5:40 pm
Try it!
Finally getting back around to this...
I tried it and it works great.
The 'u' in
...u'Spreadsheet.MyBool'...
, from Python searches, appears to be unicode operator? Is that right? And any non zero value is true?
How does one do that for, say, Pad > Type which is probably an enumerated value?
I tried:
App.ActiveDocument.Pad.setExpression('Type', u'Spreadsheet.PadType')
with different values 0, 1, 2, 3, 4 but that errors out when it evaluates the cell.
I also tried other than 'u' to no avail.
(I couldn't really find a good reference for the construct in Python docs (probably don't know what to search for...) and I still get cross eyed when I attempt to read the API docs for FreeCAD. :? :roll: )
Roy_043
Postby Roy_043 » Tue Aug 11, 2020 8:22 pm
I think so too. But I am not sure.
Pad Type is a string value. You can easily check this:
App.ActiveDocument.Pad.Type
DeepSOIC
Postby DeepSOIC » Tue Aug 11, 2020 11:53 pm
BTW, it doesn't have to be done with a macro/py console. In 0.19, realthunder has added a gui method, too.
1. Right-click in property editor, "Show all"
2. Right-click on the property you want to drive with an expression, click "Expression", type the expression, done!
With this method, it is also possible to assign vectors and placements in one go.
