Help in designing an Archimedes Wind Turbine
benfoot
Postby benfoot » Mon Aug 10, 2020 5:21 pm
Help! i would like to design the blades of an Archimedes wind turbine, but I do not know how to start!
I would consider myself an intermediate, but infrequent user of FreeCAD and I have mainly used it to design rectangular and cylindrical shapes for 3D printing. Now, I would like to use FreeCAD to design the Archimedes blades (see attached image) in a DIY wind harvesting project. I would really appreciated any tips or help to set me off in the right direction.
Re: Help in designing an Archimedes Wind Turbine
Postby chrisb » Mon Aug 10, 2020 8:04 pm
You can try a helix with an angle, or a noral helix where you cut material away with a groove. Shortly before christmas I posted Roland's christmas tree which may serve as inspiration.
papyblaise
Postby papyblaise » Tue Aug 11, 2020 6:24 am
One exemple
da Vinci helico.FCStd
(525.75 KiB) Downloaded 21 times
da Vinci helico.PNG (47.83 KiB) Viewed 740 times
hammax
Postby hammax » Tue Aug 11, 2020 6:33 am
... having some doubt concerning the aerodynamic efficiency of that prop,
here is a possible design method in FC.
SpWindTurbine_2.FCStd
(369.98 KiB) Downloaded 23 times
SpWindTurbine.FCStd
FC.18.4
(345.87 KiB) Downloaded 22 times
hammax
Postby hammax » Tue Aug 11, 2020 8:44 am
... which way does the wind come from?
SpWindTurbine_3.FCStd
(476.78 KiB) Downloaded 25 times
thschrader
Postby thschrader » Tue Aug 11, 2020 10:06 am
http://www.archimedesgreenenergys.com/about.htm
papyblaise
Postby papyblaise » Tue Aug 11, 2020 10:16 am
it is surprising it seems that there are only 2 propellers offset at 90 °, it must be unbalance :?:
hammax
Postby hammax » Tue Aug 11, 2020 1:18 pm
... my estimation is:
unrolling the blade gives a regular disc. Maybe some sector must be cut out => better not after some finetuning.
A simple part in aluminum with some bolts and a pipe as axle.
3 blades.
SpWindTurbine_4.FCStd
(230.39 KiB) Downloaded 24 times
GeneFC
Postby GeneFC » Tue Aug 11, 2020 3:39 pm
Some of the images seem to show only two blades, but when you look at more details it appears that three blades are used. Looks balanced. I have no idea if it is just "cute" or if it is really a good choice.
Gene
papyblaise
Postby papyblaise » Tue Aug 11, 2020 3:48 pm
Ho jes , Ok , whith 3 blades we can to have a good equilibre
