Help in designing an Archimedes Wind Turbine
Help! i would like to design the blades of an Archimedes wind turbine, but I do not know how to start!
I would consider myself an intermediate, but infrequent user of FreeCAD and I have mainly used it to design rectangular and cylindrical shapes for 3D printing. Now, I would like to use FreeCAD to design the Archimedes blades (see attached image) in a DIY wind harvesting project. I would really appreciated any tips or help to set me off in the right direction.
Re: Help in designing an Archimedes Wind Turbine
You can try a helix with an angle, or a noral helix where you cut material away with a groove. Shortly before christmas I posted Roland's christmas tree which may serve as inspiration.
- papyblaise
One exemple
- da Vinci helico.FCStd
- (525.75 KiB) Downloaded 68 times
- da Vinci helico.PNG (47.83 KiB) Viewed 1812 times
... having some doubt concerning the aerodynamic efficiency of that prop,
here is a possible design method in FC.
- SpWindTurbine_2.FCStd
- (369.98 KiB) Downloaded 73 times
- SpWindTurbine.FCStd
- FC.18.4
- (345.87 KiB) Downloaded 76 times
... which way does the wind come from?
- SpWindTurbine_3.FCStd
- (476.78 KiB) Downloaded 92 times
- papyblaise
it is surprising it seems that there are only 2 propellers offset at 90 °, it must be unbalance
... my estimation is:
unrolling the blade gives a regular disc. Maybe some sector must be cut out => better not after some finetuning.
A simple part in aluminum with some bolts and a pipe as axle.
3 blades.
3 blades.
- SpWindTurbine_4.FCStd
- (230.39 KiB) Downloaded 77 times
Some of the images seem to show only two blades, but when you look at more details it appears that three blades are used. Looks balanced. I have no idea if it is just "cute" or if it is really a good choice.papyblaise wrote: ↑Tue Aug 11, 2020 10:16 am it is surprising it seems that there are only 2 propellers offset at 90 °, it must be unbalance
Gene
- papyblaise
Ho jes , Ok , whith 3 blades we can to have a good equilibre
