[ Ticket #4436 ] [ Bug ] Points_Structure command does not work properly
Roy_043
Postby Roy_043 » Sat Aug 22, 2020 12:04 pm
As far as I understand things the Points_Structure command should sort the points in a point cloud. The current algorithm seems flawed as only the X and Y coordinates of a point are used in the sorting process and to determine the index of the point in the new point cloud.
src\Mod\Points\Gui\Command.cpp Line 434:
                if (xx < 0.01 && yy < 0.01) {
                    xi = std::round(xi);
                    yi = std::round(yi);
                    long index = long(yi * width_l + xi);
                    sortedPoints[index] = pnt;
Example:
pt1: 0,0,0
pt2: 0,0,1
pt1 and pt2 will receive the same index in the structured point cloud. Which effectively means that pt1 is overwritten by pt2.
Also the structured point cloud can have 'nan' vectors which the algorithm should only use temporarily. See the attached file.
App.ActiveDocument.Test13__Structured_.Points.Points
[Vector (0.0, 0.0, 2.0), Vector (nan, nan, nan), Vector (1.0, 0.0, 2.0), Vector (nan, nan, nan), Vector (0.5, 0.5, 2.5), Vector (nan, nan, nan), Vector (0.0, 1.0, 2.0), Vector (nan, nan, nan), Vector (1.0, 1.0, 2.0)]
OS: Windows 8.1 (6.3)
Version: 0.19.22262 (Git)
Hash: f56825c79f11b75648a7a0dcc8a9f52bb4574e61
Python version: 3.6.8
Qt version: 5.12.1
Test_Points_Structure.FCStd
(3.52 KiB) Downloaded 7 times
Roy_043
Re: [ Bug ] Points_Structure command does not work properly
Postby Roy_043 » Tue Sep 08, 2020 8:20 am
Bump! Can someone confirm this please. Thanks.
Roy_043
Postby Roy_043 » Tue Sep 15, 2020 8:12 am
