[Bug 4428] Search sometimes fails in 0.19 and is generally less functional then 0.18
TedM
Re: BUG: Search sometimes fails in 0.19 and is generally less functional then 0.18
Postby TedM » Fri Sep 04, 2020 10:56 pm
chrisb wrote:
Fri Sep 04, 2020 8:42 pm
So it's a different search. Ted, as a workaround you can use SelectionView, it works as you expect the other search to be.
Agreed, Selection view works fine. I was unaware of it.
I will submit submit a bug report for the context menu search.
Thanks, all.
Postby chrisb » Fri Sep 04, 2020 11:15 pm
Please create crossreferences between the bug report and this topic.
TedM
Postby TedM » Fri Sep 04, 2020 11:21 pm
Always!
TedM
Postby TedM » Sat Sep 05, 2020 6:04 pm
I should add that this regression comes up in a second context. It also comes up on the "Link" box from clicking the "[...]" on the Shapes Entry in the Fusion properties. The non-functionality is identical so I am including this in the bug report.
TedM
Postby TedM » Sat Sep 05, 2020 6:34 pm
Added to bug tracker: issue #4428
realthunder
Re: [Bug 4428] Search sometimes fails in 0.19 and is generally less functional then 0.18
Postby realthunder » Sun Sep 06, 2020 7:32 am
PR submitted here.
The tree view search box in 0.18 was replaced by the expression completer, so that you can type in a fully qualified object path to find child object without ambiguity. Use DocumentName#ObjectName.SubObject to search for object in a particular document. You'll likely see these type of reference in error message in report view. Use <<Label>> to refer document/object by its label. The search also account for the current selected object in tree view. You can use expression start with a '.' to search child of the current selected object. The same thing goes for the search box in the link property editor.
This PR enables Qt::MatchContains filtering mode in the completer to support autocomplete with substring matching. It only works with Qt5. I've done some brief testing, and the performance seems fine. I have enabled substring matching in completer (i.e. property editor, spreadsheet, etc.) by default. It can be turned off by creating a boolean parameter BaseApp/Preferences/Expression/CompleterMatchExact, and set it to True.
Postby Kunda1 » Fri Sep 11, 2020 5:17 pm
PR submitted here.
@realthunder, if there is a ticket open in Mantis, please reference it in the PR so it uses Github webhooks to autoclose ticket.
Fixes #4428
(doesn't have to be in the commit title, it can be added to the commit body).
See Tracker#GitHub_and_MantisBT
realthunder
Postby realthunder » Sat Sep 12, 2020 1:50 am
Fixes #4428
Yes. Forgot about it.
