[Solved] Copy geometry from other sketch, can't change easily constraints
I've setup a sketch (sketch001) to draw holes in an extrusion (sketch).
To complete my design I wanted to do a new sketch (sketch002) and copy a geometry form sketch001.
All seems ok, but I hit a kind bug in the UI , I can't easily change the constraints.
I've made a short video showing the issue:
https://drive.google.com/file/d/1Nz6GlD ... xCxTg/view
When I try to change the constraint from 70mm to 60mm in sketch002 it is a real pain to modify it. (constraint is in orange, so you always have to click on little blue button to modify anything.)
Is there a way to remove the "orange" property?
Re: Copy geometry from other sketch, can't change easily constraints
Instead of using Carbon copy use ext geometry
Your first post, welcome to FreeCAD.
I moved this to Help forum since its a help request.
Please always post your version data, how to do so is explained in the Forum Rules link above this forum.
Here is the wiki page for Expressions
If you want to remove the expression, click on the blue Expression icon then click on the "clear" button in the expression editor, then click OK, and you will be back to an standard constraint (red) with its value taken from the last value calculated by the previous Expression.
Here is a screen shot
OS: Ubuntu 18.04.5 LTS (KDE/plasma)
Version: 0.19.
Branch: unknown
Hash: 46209e7f7759713ccd0fb31da2fa7bd26e116c8a
Python version: 3.6.9
Qt version: 5.9.5
Its not a bug, they are easily to edit
The yare orange because you have defined them with an Expression rather than just a value. By definition you should not be able to edit them unless you edit or remove the expressions, or change the value of whatever you are reading with that expression.
Version: 0.19.
Branch: unknown
Qt version: 5.9.5
An easier way I've found to clear the expression is to click the "reference" checkbox twice. The first click clears the expression and turns the constraint into a reference, which measures the distance instead of setting it. The second click turns it back into a constraint but with just a simple value.jmaustpc wrote: ↑Sat Sep 12, 2020 12:55 pm Your first post, welcome to FreeCAD.
Version: 0.19.
Branch: unknown
Qt version: 5.9.5
Ted, please don't quote whole posts. Restrict yourself to the parts you are directly refering to. Those who want to read the whole post again can follow the up-arrow link to get there.
As the constraints are used by their numbers they can create problems similar to the topological naming problem.
That is true particularly in this case, but that is why I said "a well designed Expression" and "can be", I meant that it depends on the details, for example where the expression gets it data from etc.chrisb wrote: ↑Wed Sep 16, 2020 10:54 pm jmaustpc wrote: ↑
12 Sep 2020, 23:08
Sort of but a well designed Expression can be less likely to suffer from a failure after edit due to the topological naming limitation.
You are, of course, right as always. I had made some tests before my post above, and I don't fully understand what's happening, but that is something for another topic.
I agree with your assessment of my "rightness", but I think my girls are slightly less inclined to agree with the "always" part. Apparently I have no fashion sense and dress like a dag!
Been there done that; "Oh dad, you're so embarrassing, can you please go at least ten steps behind us?". At least they didn't say "Be good and behave, you stay in the car".
