Importing Step with Colors
Re: Importing Step with Colors
OS: Windows 10 Version 2009
Version: 0.19.24276 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Just some additional anecdotal information pertaining to importing / opening STEP files. I use FreeCAD to view automation components, and get their STEP files. When opening a STEP0214 file, it immediately appear in its colors, then immediately turns to grey. This has happened on multiple attempts, different object files (all STEP0214).
After loading a Part WB, I went to Preferences and saw that in Import/Export, there are additional tabs for various file formats. When opening a file, I selected the STEP0214 version in <Filetype> and it displayed correctly with its intended colors.
The anomaly I noticed is when opening/importing, the colors appear very briefly, then go to gray. When the Part WB is loaded, the intended colors remain.
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Please retry with a current version. I have created a Step file from FreeCAD with differently colored faces. When I import it the colors persist. Tested in Draft and PartDesign workbench.
I have left the preferences at their default settings.
I attach the file, in case it is not the import, but rather the export.
OS: macOS 10.16
Version: 0.20.24825 (Git)
Hash: ccc4151b3020969450325466e385850783795325
Python version: 3.9.2
Qt version: 5.12.9
Coin version: 4.0.0
OCC version: 7.5.1
Locale: C/Default (C)
OS: macOS 10.16
Qt version: 5.12.9
Coin version: 4.0.0
OCC version: 7.5.1
- colored.step
- (37.9 KiB) Downloaded 56 times
I have also color problems with step import/export.
Version: 0.20.26155 (Git)
Hash: 0926a4148bcff11249fd4f56bc30256102ffe105
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
When i do a doubleclick of the attached color step test file i get an import with colored faces.
When i do a PART-FILE-IMPORT step i get a part without color faces.
And even with the "doubleclick import" part i lose the color information when i do a step export.
What can i try to get colored step models when i do import/export step file?
EDIT: With 0.18 i can import and export colored 3D models without any problem.
Joachim
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Joachim
hi,
I have no issue both in opening or importing the 'colored.step' file from @crisb
I remember that once I had some issue on step colors because of a messed up configuration file/folder (due to many different FC versions installed)
If you backup your configuration and then delete it, you may solve your issue.
Remember to check the STEP import/export setting after the resetting of the config.
P.S. I also suggest you to uncheck the option to export curve in parametric because it increases a lot the step file size with useless data
App.newDocument("Unnamed")
Gui.activeDocument().activeView().viewDefaultOrientation()
### End command Std_New
### Begin command Std_Import
import ImportGui
ImportGui.insert(u"c:/Temp/colored.step","Unnamed")
### End command Std_Import
With version 0.18 i was able to download and to start an installation program.
With version 0.20 i find only a zip file, which i extracted. There was no installation necessary.
Could this cause the problem because FC 0.20 is not installed, i just start the FREECAD.EXE
it shouldn't be an issue...grijo wrote: ↑Mon Nov 29, 2021 10:19 am With version 0.18 i was able to download and to start an installation program.
https://wiki.freecadweb.org/Start_up_and_Configuration
What i tried today:
I deinstalled FC 0.18.
I deleted FC 0.20 directory
I downloaded and unzipped FC 0.2. again
I did then an additional test with the colored.fcstd file you have provided.
When i doubleklick on the file and FC is starting, i get the body with colors. ( left side in pic )
When i open FC and i import the step file, or even if i drag and drop it to a running FC window, the body is completly grey. ( right side in pic )
EDIT:
A friend who is working with FC, too, did the test for me to doublecheck.
He has the same behaviour like me, doubleclick is starting the sTEP file with displayed color.
Import or drag&drap is showing the body without color.
EDIT:
UserAppData Path where FreeCAD stores User Related application data.
if you digit in a command prompt:
it should be in:
1) you should copy the actual FreeCAD User Related Application Data to a backup place (folder)
2) delete the actual FreeCAD User Related Application Data folder
3) launch FC0.20, check the STEP Import/Export settings in FC Gui
4) import the file
%APPDATA%\FreeCAD
C:\Documents and Settings\YOURUSERNAME\AppData\FreeCAD
4) import the file
My path is:
c:\users\xxxx\AppData\Roaming\FreeCad
I deleted the ...Roaming/Freecad directory, then i started Freecad.
The Freecad directory was created by FC with 2 subdirectories ( Macro and webdatapersistant, and a user.cfg )
Then i checked the STEP settings and tried to open the step file.
Same behaviour, no colors.
Joachim
Joachim
Today i downloaded the last win-conda version from weekly builds download site.
OS: Windows 10 (10.0)
Version: 0.20.26683 (Git)
Python version: 3.8.12
Qt version: 5.12.9
Coin version: 4.0.0
OCC version: 7.5.3
Before is installed this verison i deleted all "old" freecad versions and cleaned the registry manually.
Now the step export and import looks fine, i get the colors ex- and imported with the step file.
Joachim
Qt version: 5.12.9
Coin version: 4.0.0
OCC version: 7.5.3
Joachim
