Slice a Body
koluna
Slice a Body
Post by koluna »
Hello!
How can I slice my Body to two parts?
It is for 3D printing. I will print my Parts separatelly and glue them.
OS: Linux Mint 19.3 (MATE/mate)
Version: 0.19.
Branch: unknown
Hash: 7459f87c88c502138edda363748b61c63ba980e2
Python version: 3.6.9
Qt version: 5.9.5
vacuumValve2.FCStd
(289.26 KiB) Downloaded 47 times
drmacro
Re: Slice a Body
Post by drmacro »
Though this tutorial is in 0.18, it has the basics:
https://www.youtube.com/watch?v=tzHkQaHgrfQ
And the FreeeCAD wiki:
https://wiki.freecadweb.org/Part_SliceApart
papyblaise
Re: Slice a Body
Post by papyblaise »
Hi
in partWb only , do a large cube (Extrude) , do a Commun , clone it and move it (red)
do a cut (limiter / commun)
do 2 STL
Remarque : maybe you have to do more than one cut because you have several parts whithout supported roof
valve.FCStd
(332.07 KiB) Downloaded 33 times
koluna
Re: Slice a Body
Post by koluna »
papyblaise wrote: Fri Sep 18, 2020 2:32 pm do a large cube (Extrude) ,
I made it in Part Design WB (additive Box). Is it ok?
do a Commun
I made it in Part WB and got an error "<Exception> Input shape is null". Why is it so?
I have already got this error when I had tried on other ways...
koluna
Re: Slice a Body
Post by koluna »
I did it in Part WB (Sketch + Extrude). It does not work too!
DeepSOIC
Re: Slice a Body
Post by DeepSOIC »
koluna wrote: Fri Sep 18, 2020 3:36 pm input shape is null
Your body has lost Tip somehow. Open PartDesign WB, right-click the last feature in tree ("Limiters") and click "Set tip" in context menu. Your body should slice apart nicely after that (at least on my machine, it does).
koluna
Re: Slice a Body
Post by koluna »
It does not work! I have already tried it!!!
koluna
Re: Slice a Body
Post by koluna »
DeepSOIC wrote: Fri Sep 18, 2020 3:44 pm Your body has lost Tip somehow.
You are right. It is a horrible abrakadabra :)
I moved and deleted some features... maybe it is a reason a bad bahaviour...
Thanks a lot! It works! :)
DeepSOIC
Re: Slice a Body
Post by DeepSOIC »
koluna wrote: Fri Sep 18, 2020 3:57 pm I moved and deleted some features... maybe it is a reason a bad bahaviour...
If you can repeat it, please report.
koluna
Re: Slice a Body
Post by koluna »
DeepSOIC wrote: Fri Sep 18, 2020 3:59 pm
Ok.
I deleted some feateres and actively used a Space key in tree navigate.
And further. Should I set the "Display Mode Body" property to "Tip" before using Part WB?
