I'm working my way through tutorials, but wanted to try to recreate an existing simple object using PartDesign workbench. Before adding holes and chamfers, I decided to export as STL, and was surprised to see in my slicer the object was not manifold. Looking at the Mesh analysis in FreeCAD I see there were two "extra" points.
What I had intended to do was create a sketch, and pad part of it to one height, and pad another part to a taller height. As I didn't see a way to extrude part of a sketch, I then created two side by side sketches, so that I could pad one to 3mm and the other to 20mm. The part looks correct, but it is not manifold. Reading through the forum, it appears it might be related to parts of the two separate sketches overlapping.
As I'm still learning, I wonder what the proper way to do this in FreeCAD.
Thanks for any advice!
John
OS: macOS 10.15
Version: 0.19.22522 (Git)
Hash: d8e476ef428017900dfe0f9359ba448503c216f9
Python version: 3.8.5
Qt version: 5.12.9
OCC version: 7.4.0
Locale: C/Default (C)
