FreeCad does not open on W10
Asouzalopes
Re: FreeCad does not open on W10
Post by Asouzalopes »
Msg: FreeCAD 0.18, Libs: 0.18R4 (GitTag)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2019
Log: Time = Thu Nov 12 16:26:11 2020
Log: AppDataSkipVendor = true
Log: AppHomePath = C:/Program Files/FreeCAD 0.18/
Log: AppIcon = freecad
Log: AppTempPath = D:\Usuários\interop.anderson\AppData\Local\Temp\
Log: BinPath = C:/Program Files/FreeCAD 0.18/bin\
Log: BuildRepositoryURL = git://github.com/FreeCAD/FreeCAD.git releases/FreeCAD-0-18
Log: BuildRevision = 4 (GitTag)
Log: BuildRevisionBranch = releases/FreeCAD-0-18
Log: BuildRevisionDate = 2019/10/22 16:53:35
Log: BuildRevisionHash = 980bf9060e28555fecd9e3462f68ca74007b70f8
Log: BuildVersionMajor = 0
Log: BuildVersionMinor = 18
Log: Console = 0
Log: CopyrightInfo = © Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2019
Log: Debug = 0
Log: DocPath = C:/Program Files/FreeCAD 0.18/doc\
Log: ExeName = FreeCAD
Log: ExeVendor = FreeCAD
Log: ExeVersion = 0.18
Log: LoggingFile = 1
Log: LoggingFileName = D:\Usuários\interop.anderson\AppData\Roaming\FreeCAD\FreeCAD.log
Log: MaintainerUrl = http://www.freecadweb.org/wiki/Main_Page
Log: PATH = C:\Program Files\FreeCAD 0.18\bin\Library\bin;C:\totvs\CorporeRM\API;C:\Program Files (x86)\Ingres\IngresII\ingres\bin;C:\Program Files (x86)\Ingres\IngresII\ingres\utility;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files (x86)\Microsoft Dynamics AX\60\Client\Bin\;C:\totvs\CorporeRM\API;D:\Usu�rios\interop.anderson\AppData\Local\Microsoft\WindowsApps;
Log: PythonSearchPath = C:\Program Files\FreeCAD 0.18\bin\python36.zip;C:\Program Files\FreeCAD 0.18\bin\DLLs;C:\Program Files\FreeCAD 0.18\bin\lib;C:\Program Files\FreeCAD 0.18\bin
Log: RunMode = Gui
Log: SplashAlignment = Bottom|Left
Log: SplashInfoColor = #c8c8c8
Log: SplashScreen = freecadsplash
Log: SplashTextColor = #ffffff
Log: StartWorkbench = StartWorkbench
Log: SystemParameter = D:\Usuários\interop.anderson\AppData\Roaming\FreeCAD\system.cfg
Log: UserAppData = D:\Usuários\interop.anderson\AppData\Roaming\FreeCAD\
Log: UserHomePath = D:\Usuários\interop.anderson\Documents
Log: UserParameter = D:\Usuários\interop.anderson\AppData\Roaming\FreeCAD\user.cfg
Log: Verbose =
Log: Create Application
Log: Run App init script
Log: Init: starting App::FreeCADInit.py
Log: Init: Searching for modules...
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\AddonManager... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Arch... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Complete... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Draft... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Drawing... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Fem... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Idf... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Image... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Import... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Inspection... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Material... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Measure... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Mesh... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\MeshPart... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\OpenSCAD... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Part... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\PartDesign... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Path... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Plot(Init.py not found)... ignore
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Points... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Raytracing... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Robot... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Ship(Init.py not found)... ignore
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Show(Init.py not found)... ignore
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Sketcher... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Spreadsheet... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Start... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Surface... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\TechDraw... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Test... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Tux(Init.py not found)... ignore
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Web... done
Log: Using C:\Program Files\FreeCAD 0.18\Mod as module path!
Log: System path after init:
Log: C:\Program Files\FreeCAD 0.18\bin
Log: C:\Program Files\FreeCAD 0.18\Mod\AddonManager
Log: C:\Program Files\FreeCAD 0.18\Mod\Arch
Log: C:\Program Files\FreeCAD 0.18\Mod\Complete
Log: C:\Program Files\FreeCAD 0.18\Mod\Draft
Log: C:\Program Files\FreeCAD 0.18\Mod\Drawing
Log: C:\Program Files\FreeCAD 0.18\Mod\Fem
Log: C:\Program Files\FreeCAD 0.18\Mod\Idf
Log: C:\Program Files\FreeCAD 0.18\Mod\Image
Log: C:\Program Files\FreeCAD 0.18\Mod\Import
Log: C:\Program Files\FreeCAD 0.18\Mod\Inspection
Log: C:\Program Files\FreeCAD 0.18\Mod\Material
Log: C:\Program Files\FreeCAD 0.18\Mod\Measure
Log: C:\Program Files\FreeCAD 0.18\Mod\Mesh
Log: C:\Program Files\FreeCAD 0.18\Mod\MeshPart
Log: C:\Program Files\FreeCAD 0.18\Mod\OpenSCAD
Log: C:\Program Files\FreeCAD 0.18\Mod\Part
Log: C:\Program Files\FreeCAD 0.18\Mod\PartDesign
Log: C:\Program Files\FreeCAD 0.18\Mod\Path
Log: C:\Program Files\FreeCAD 0.18\Mod\Plot
Log: C:\Program Files\FreeCAD 0.18\Mod\Points
Log: C:\Program Files\FreeCAD 0.18\Mod\Raytracing
Log: C:\Program Files\FreeCAD 0.18\Mod\Robot
Log: C:\Program Files\FreeCAD 0.18\Mod\Ship
Log: C:\Program Files\FreeCAD 0.18\Mod\Show
Log: C:\Program Files\FreeCAD 0.18\Mod\Sketcher
Log: C:\Program Files\FreeCAD 0.18\Mod\Spreadsheet
Log: C:\Program Files\FreeCAD 0.18\Mod\Start
Log: C:\Program Files\FreeCAD 0.18\Mod\Surface
Log: C:\Program Files\FreeCAD 0.18\Mod\TechDraw
Log: C:\Program Files\FreeCAD 0.18\Mod\Test
Log: C:\Program Files\FreeCAD 0.18\Mod\Tux
Log: C:\Program Files\FreeCAD 0.18\Mod\Web
Log: C:\Program Files\FreeCAD 0.18\bin\Library\bin
Log: C:\totvs\CorporeRM\API
Log: C:\Program Files (x86)\Ingres\IngresII\ingres\bin
Log: C:\Program Files (x86)\Ingres\IngresII\ingres\utility
Log: C:\Program Files (x86)\Common Files\Oracle\Java\javapath
Log: C:\WINDOWS\system32
Log: C:\WINDOWS
Log: C:\WINDOWS\System32\Wbem
Log: C:\WINDOWS\System32\WindowsPowerShell\v1.0\
Log: C:\WINDOWS\System32\OpenSSH\
Log: C:\Program Files (x86)\Microsoft Dynamics AX\60\Client\Bin\
Log: D:\Usuários\interop.anderson\AppData\Local\Microsoft\WindowsApps
Log:
Log: Init: App::FreeCADInit.py done
Log: Init: Creating Gui::Application and QApplication
Log: Local server 'FreeCAD' started
Log: OpenGL version is: 4.6 (4.6.13559 Compatibility Profile Context 26.20.12028.2)
Log: Run Gui init script
Log: Init: Running FreeCADGuiInit.py start script...
Log: Init: Searching modules...
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Idf(InitGui.py not found)... ignore
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Measure(InitGui.py not found)... ignore
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Plot... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Ship... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Show(InitGui.py not found)... ignore
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Tux... done
Log: Init: Loading FreeCAD GUI
Log: Init: Running FreeCADGuiInit.py start script... done
Log: Init: Activating default workbench StartWorkbench
Log: Loading GUI of Web module... done
Log: Loading GUI of Start module... done
Log: Loading Start module... done
Log: Init: Showing main window
Log: Main window restored
Log: Show main window
Log: Toolbars restored
Log: 3Dconnexion device not attached.
Log: Init: Entering event loop
Asouzalopes wrote: Thu Nov 12, 2020 7:28 pm Msg: FreeCAD 0.18, Libs: 0.18R4 (GitTag)
Please retry with current 0.19 version and report back. If you post log file output, place it between code tags (button </>) It keeps indentations and is easier to read.
Asouzalopes
Msg: FreeCAD 0.19, Libs: 0.19R22988 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2020
FreeCAD is free and open-source software licensed under the terms of LGPL2+ license.
FreeCAD wouldn't be possible without FreeCAD community.
Log: Time = Fri Nov 13 08:33:09 2020
Log: AppHomePath = D:/FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64/
Log: BinPath = D:/FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64/bin\
Log: BuildRepositoryURL = git://github.com/FreeCAD/FreeCAD.git master
Log: BuildRevision = 22988 (Git)
Log: BuildRevisionBranch = master
Log: BuildRevisionDate = 2020/11/11 15:52:16
Log: BuildRevisionHash = cdc01cb20cfa74079c45b9dc2dab81e3248b2aa5
Log: BuildVersionMinor = 19
Log: Console = 0
Log: CopyrightInfo = © Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2020
Log: Debug = 0
Log: DocPath = D:/FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64/doc\
Log: ExeVersion = 0.19
Log: LoggingConsole = 1
Log: PATH = C:\totvs\CorporeRM\API;C:\Program Files (x86)\Ingres\IngresII\ingres\bin;C:\Program Files (x86)\Ingres\IngresII\ingres\utility;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files (x86)\Microsoft Dynamics AX\60\Client\Bin\;C:\totvs\CorporeRM\API;D:\Usu�rios\interop.anderson\AppData\Local\Microsoft\WindowsApps;
Log: PythonSearchPath = D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\bin\python36.zip;D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\bin\DLLs;D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\bin\lib;D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\bin
Log: RunMode = Gui
Log: Verbose =
Log: Init:      Initializing D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\AddonManager... done
Log: Init:      Initializing D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Arch... done
Log: Init:      Initializing D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Complete... done
Log: Init:      Initializing D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Draft... done
Log: Drawing became obsolete in 0.17; consider using TechDraw instead.
Log: Init:      Initializing D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Drawing... done
Log: Init:      Initializing D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Fem... done
Log: Init:      Initializing D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Idf... done
Log: Init:      Initializing D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Image... done
Log: Init:      Initializing D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Import... done
Log: Init:      Initializing D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Inspection... done
Log: Init:      Initializing D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Material... done
Log: Init:      Initializing D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Measure... done
Log: Init:      Initializing D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Mesh... done
Log: Init:      Initializing D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\MeshPart... done
Log: Init:      Initializing D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\OpenSCAD... done
Log: Init:      Initializing D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Part... done
Log: Init:      Initializing D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\PartDesign... done
Log: Init:      Initializing D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Path... done
Log: Init:      Initializing D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Points... done
Log: Init:      Initializing D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Raytracing... done
Log: Init:      Initializing D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\ReverseEngineering... done
Log: Init:      Initializing D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Robot... done
Log: Init:      Initializing D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Show(Init.py not found)... ignore
Log: Init:      Initializing D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Sketcher... done
Log: Init:      Initializing D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Spreadsheet... done
Log: Init:      Initializing D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Start... done
Log: Init:      Initializing D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Surface... done
Log: Init:      Initializing D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\TechDraw... done
Log: Init:      Initializing D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Test... done
Log: Init:      Initializing D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Tux(Init.py not found)... ignore
Log: Init:      Initializing D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Web... done
Log: Using D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod as module path!
Log:    D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\bin
Log:    D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\AddonManager
Log:    D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Arch
Log:    D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Complete
Log:    D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Draft
Log:    D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Drawing
Log:    D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Fem
Log:    D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Idf
Log:    D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Image
Log:    D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Import
Log:    D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Inspection
Log:    D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Material
Log:    D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Measure
Log:    D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Mesh
Log:    D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\MeshPart
Log:    D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\OpenSCAD
Log:    D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Part
Log:    D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\PartDesign
Log:    D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Path
Log:    D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Points
Log:    D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Raytracing
Log:    D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\ReverseEngineering
Log:    D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Robot
Log:    D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Show
Log:    D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Sketcher
Log:    D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Spreadsheet
Log:    D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Start
Log:    D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Surface
Log:    D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\TechDraw
Log:    D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Test
Log:    D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Tux
Log:    D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Web
Log:    C:\WINDOWS
Log:
Log: Init:      Initializing D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Idf(InitGui.py not found)... ignore
Log: Init:      Initializing D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Measure(InitGui.py not found)... ignore
Log: Init:      Initializing D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Show(InitGui.py not found)... ignore
Log: Init:      Initializing D:\FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64\Mod\Tux... done
Log: Installed Qt WebEngine locales directory not found at location D:/FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64/translations\qtwebengine_locales. Trying application directory...
Log: Qt WebEngine locales directory not found at location D:/FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64/bin\qtwebengine_locales. Trying fallback directory... Translations MAY NOT not be correct.
Sorry but I don't understand," put it between the code tags (</> button). It maintains indentations and is easier to read."
Asouzalopes wrote: Fri Nov 13, 2020 11:38 am Sorry but I don't understand," put it between the code tags (</> button). It maintains indentations and is easier to read."
- Edit the post with the pencil button in the right upper corner
- mark the log output
- click the button showing the symbols "</>" above the edit field.
And don't post the output a third time.
GeneFC
Post by GeneFC »
I edited your post to show what is wanted.
Gene
There is nothing strange I can see in the log. Two things are uncommon though, but I don't think they cause your issue. To rule them out, you may change them anyway:
- Your username contains a non ASCII character, you may add another user without that.
- Your user directories lie on D:, while they are usually on C:
Did you look at the Known OS specific issues page?
Asouzalopes
chrisb wrote: Fri Nov 13, 2020 9:13 pm There is nothing strange I can see in the log. Two things are uncommon though, but I don't think they cause your issue. To rule them out, you may change them anyway:
Yes, I searched this link without success.
I've done the informed tests and nothing has resolved.
I used the portable version and it also doesn't open.
chiliontan
Post by chiliontan »
Hi, I have same problem when using corporate issued laptop OS Window10. frrecad version 0.19.2. I was able to use it for short while but after about 2 weeks, it tries to start (launch script was running) but nothing happen.
I tried to launch via window10 cmd prompt 'Freecad.exe -l' but got an error "Freecad.exe' is not recognized as an internal or external command,
operable program or batch file.".
adrianinsaval
Post by adrianinsaval »
you need to open the command prompt in the bin folder in your freecad folder or navigate to that folder in cmd
desweller
Post by desweller »
Do you have any whitelist endpoint program active on your machine? I have experienced this sort of silent quit behaviour on some of our in-house apps before they were added to the corporate whitelist.
