Steps to reproduce.
1. Open the attached file (part3.FCstd)
2. Create a new subtractive loft starting with inner_0_sk
3. Added sketches inner_1_sk, inner_2_sk, and inner_3_sk in that order.
4. Click OK to accept the loft.
5. FreeCAD crashes.
The following is reported on the terminal
FreeCAD 0.19, Libs: 0.19R22665 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2020
FreeCAD is free and open-source software licensed under the terms of LGPL2+ license.
FreeCAD wouldn't be possible without FreeCAD community.
Loading Assembly4 WorkBench
#0 /lib/x86_64-linux-gnu/libc.so.6(+0x3be30) [0x7fd576ecbe30]
#1 /tmp/.mount_FreeCAA40B2C/usr/lib/./libTKBool.so.7(+0x270559) [0x7fd54f94e559]
#2 0x7fd54f9aef1b in BRepFill_CompatibleWires::SameNumberByPolarMethod(bool) from /tmp/.mount_FreeCAA40B2C/usr/lib/./libTKBool.so.7+0x130b
#3 0x7fd54f9b487a in BRepFill_CompatibleWires::Perform(bool) from /tmp/.mount_FreeCAA40B2C/usr/lib/./libTKBool.so.7+0xb6a
#4 0x7fd554b3b196 in BRepOffsetAPI_ThruSections::Build() from /tmp/.mount_FreeCAA40B2C/usr/lib/./libTKOffset.so.7+0x296
#5 0x7fd4ec437037 in PartDesign::Loft::execute() from /tmp/.mount_FreeCAA40B2C/usr/lib/_PartDesign.so+0x7f7
#6 0x7fd578c66ea2 in App::DocumentObject::recompute() from /tmp/.mount_FreeCAA40B2C/usr/bin/../lib/libFreeCADApp.so+0xf2
#7 0x7fd5552a713c in Part::Feature::recompute() from /tmp/.mount_FreeCAA40B2C/usr/lib/Part.so+0xc
#8 0x7fd578bf906c in App::Document::_recomputeFeature(App::DocumentObject*) from /tmp/.mount_FreeCAA40B2C/usr/bin/../lib/libFreeCADApp.so+0x31c
#9 0x7fd578c528bc in App::Document::recompute(std::vector<App::DocumentObject*, std::allocator<App::DocumentObject*> > const&, bool, bool*, int) from /tmp/.mount_FreeCAA40B2C/usr/bin/../lib/libFreeCADApp.so+0x60c
#10 0x7fd578cba5b2 in App::DocumentPy::recompute(_object*) from /tmp/.mount_FreeCAA40B2C/usr/bin/../lib/libFreeCADApp.so+0x382
#11 0x7fd578cbaa54 in App::DocumentPy::staticCallback_recompute(_object*, _object*) from /tmp/.mount_FreeCAA40B2C/usr/bin/../lib/libFreeCADApp.so+0x24
#12 /tmp/.mount_FreeCAA40B2C/usr/bin/../lib/libpython3.8.so.1.0(PyCFunction_Call+0xf7) [0x7fd5790ca2e7]
#13 /tmp/.mount_FreeCAA40B2C/usr/bin/../lib/libpython3.8.so.1.0(_PyObject_MakeTpCall+0x250) [0x7fd579080890]
#14 /tmp/.mount_FreeCAA40B2C/usr/bin/../lib/libpython3.8.so.1.0(_PyEval_EvalFrameDefault+0x4ea2) [0x7fd57910ee62]
#15 /tmp/.mount_FreeCAA40B2C/usr/bin/../lib/libpython3.8.so.1.0(_PyEval_EvalCodeWithName+0x2e2) [0x7fd57907d022]
#16 /tmp/.mount_FreeCAA40B2C/usr/bin/../lib/libpython3.8.so.1.0(PyEval_EvalCodeEx+0x44) [0x7fd57907dde4]
#17 /tmp/.mount_FreeCAA40B2C/usr/bin/../lib/libpython3.8.so.1.0(PyEval_EvalCode+0x1c) [0x7fd57913369c]
#18 /tmp/.mount_FreeCAA40B2C/usr/bin/../lib/libpython3.8.so.1.0(+0x219ecf) [0x7fd579151ecf]
#19 /tmp/.mount_FreeCAA40B2C/usr/bin/../lib/libpython3.8.so.1.0(+0x252c44) [0x7fd57918ac44]
#20 /tmp/.mount_FreeCAA40B2C/usr/bin/../lib/libpython3.8.so.1.0(PyRun_StringFlags+0x7d) [0x7fd57918acdd]
#21 0x7fd57898a11a in Base::InterpreterSingleton::runString[abi:cxx11](char const*) from /tmp/.mount_FreeCAA40B2C/usr/bin/../lib/libFreeCADBase.so+0x6a
#22 0x7fd579723af8 in Gui::Command::_runCommand(char const*, int, Gui::Command::DoCmd_Type, char const*) from /tmp/.mount_FreeCAA40B2C/usr/bin/../lib/libFreeCADGui.so+0x98
#23 0x7fd4d1f97bd2 in void Gui::_cmdDocument<char const (&) [12]>(Gui::Command::DoCmd_Type, App::Document const*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, char const (&) [12]) from /tmp/.mount_FreeCAA40B2C/usr/lib/PartDesignGui.so+0x4b2
#24 0x7fd4d1f98465 in PartDesignGui::TaskDlgFeatureParameters::accept() from /tmp/.mount_FreeCAA40B2C/usr/lib/PartDesignGui.so+0x145
#25 0x7fd4d1f9be98 in PartDesignGui::TaskDlgSketchBasedParameters::accept() from /tmp/.mount_FreeCAA40B2C/usr/lib/PartDesignGui.so+0x4b8
#26 0x7fd4d2028259 in PartDesignGui::TaskDlgLoftParameters::accept() from /tmp/.mount_FreeCAA40B2C/usr/lib/PartDesignGui.so+0x579
#27 0x7fd5799c44e9 in Gui::TaskView::TaskView::accept() from /tmp/.mount_FreeCAA40B2C/usr/bin/../lib/libFreeCADGui.so+0x59
#28 0x7fd5773c60d2 in QMetaObject::activate(QObject*, int, int, void**) from /tmp/.mount_FreeCAA40B2C/usr/bin/../lib/libQt5Core.so.5+0x780
#29 /tmp/.mount_FreeCAA40B2C/usr/bin/../lib/libQt5Widgets.so.5(+0x274d73) [0x7fd577cdad73]
#30 0x7fd5773c60d2 in QMetaObject::activate(QObject*, int, int, void**) from /tmp/.mount_FreeCAA40B2C/usr/bin/../lib/libQt5Core.so.5+0x780
#31 0x7fd577c73360 in QAbstractButton::clicked(bool) from /tmp/.mount_FreeCAA40B2C/usr/bin/../lib/libQt5Widgets.so.5+0x32
#32 /tmp/.mount_FreeCAA40B2C/usr/bin/../lib/libQt5Widgets.so.5(+0x20da19) [0x7fd577c73a19]
#33 /tmp/.mount_FreeCAA40B2C/usr/bin/../lib/libQt5Widgets.so.5(+0x20e2ae) [0x7fd577c742ae]
#34 0x7fd577c7434a in QAbstractButton::mouseReleaseEvent(QMouseEvent*) from /tmp/.mount_FreeCAA40B2C/usr/bin/../lib/libQt5Widgets.so.5+0x88
#35 0x7fd577c05c23 in QWidget::event(QEvent*) from /tmp/.mount_FreeCAA40B2C/usr/bin/../lib/libQt5Widgets.so.5+0x135
#36 0x7fd577bda83a in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /tmp/.mount_FreeCAA40B2C/usr/bin/../lib/libQt5Widgets.so.5+0xde
#37 0x7fd577bdf0a9 in QApplication::notify(QObject*, QEvent*) from /tmp/.mount_FreeCAA40B2C/usr/bin/../lib/libQt5Widgets.so.5+0x79d
#38 0x7fd5796f10c9 in Gui::GUIApplication::notify(QObject*, QEvent*) from /tmp/.mount_FreeCAA40B2C/usr/bin/../lib/libFreeCADGui.so+0x89
#39 0x7fd5773afa9c in QCoreApplication::notifyInternal2(QObject*, QEvent*) from /tmp/.mount_FreeCAA40B2C/usr/bin/../lib/libQt5Core.so.5+0x88
#40 0x7fd577bde553 in QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool, bool) from /tmp/.mount_FreeCAA40B2C/usr/bin/../lib/libQt5Widgets.so.5+0x283
#41 /tmp/.mount_FreeCAA40B2C/usr/bin/../lib/libQt5Widgets.so.5(+0x1af580) [0x7fd577c15580]
#42 /tmp/.mount_FreeCAA40B2C/usr/bin/../lib/libQt5Widgets.so.5(+0x1b03d2) [0x7fd577c163d2]
#43 0x7fd577bda83a in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /tmp/.mount_FreeCAA40B2C/usr/bin/../lib/libQt5Widgets.so.5+0xde
#44 0x7fd577be0405 in QApplication::notify(QObject*, QEvent*) from /tmp/.mount_FreeCAA40B2C/usr/bin/../lib/libQt5Widgets.so.5+0x1af9
#45 0x7fd5796f10c9 in Gui::GUIApplication::notify(QObject*, QEvent*) from /tmp/.mount_FreeCAA40B2C/usr/bin/../lib/libFreeCADGui.so+0x89
#46 0x7fd5773afa9c in QCoreApplication::notifyInternal2(QObject*, QEvent*) from /tmp/.mount_FreeCAA40B2C/usr/bin/../lib/libQt5Core.so.5+0x88
#47 0x7fd577756724 in QGuiApplicationPrivate::processMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*) from /tmp/.mount_FreeCAA40B2C/usr/bin/../lib/libQt5Gui.so.5+0x684
#48 0x7fd5777572f7 in QGuiApplicationPrivate::processWindowSystemEvent(QWindowSystemInterfacePrivate::WindowSystemEvent*) from /tmp/.mount_FreeCAA40B2C/usr/bin/../lib/libQt5Gui.so.5+0x175
#49 0x7fd577744020 in QWindowSystemInterface::sendWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /tmp/.mount_FreeCAA40B2C/usr/bin/../lib/libQt5Gui.so.5+0x64
#50 /tmp/.mount_FreeCAA40B2C/usr/plugins/platforms/../../lib/libQt5XcbQpa.so.5(+0x5b1ea) [0x7fd57314a1ea]
#51 /tmp/.mount_FreeCAA40B2C/usr/bin/../lib/./libglib-2.0.so.0(g_main_context_dispatch+0x2cb) [0x7fd574384dab]
#52 /tmp/.mount_FreeCAA40B2C/usr/bin/../lib/./libglib-2.0.so.0(+0x54ff1) [0x7fd574384ff1]
#53 /tmp/.mount_FreeCAA40B2C/usr/bin/../lib/./libglib-2.0.so.0(g_main_context_iteration+0x2e) [0x7fd57438507e]
#54 0x7fd5773ded23 in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /tmp/.mount_FreeCAA40B2C/usr/bin/../lib/libQt5Core.so.5+0x63
#55 0x7fd5773ac4d7 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) from /tmp/.mount_FreeCAA40B2C/usr/bin/../lib/libQt5Core.so.5+0x187
#56 0x7fd5773b034f in QCoreApplication::exec() from /tmp/.mount_FreeCAA40B2C/usr/bin/../lib/libQt5Core.so.5+0x105
#57 0x7fd5796674f2 in Gui::Application::runApplication() from /tmp/.mount_FreeCAA40B2C/usr/bin/../lib/libFreeCADGui.so+0x15a2
#58 /tmp/.mount_FreeCAA40B2C/usr/bin/freecad(+0x37cd) [0x5573e3a717cd]
#59 /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xea) [0x7fd576eb6cca]
#60 /tmp/.mount_FreeCAA40B2C/usr/bin/freecad(+0x4521) [0x5573e3a72521]
