Black Boxes - Bug or Driver Issue?
HubertFarnsworth
Postby HubertFarnsworth » Wed Oct 21, 2020 1:18 am
Hi All,
I've just started using FreeCAD and it's awesome. However, I've run into one issue that's making concentrating very difficult (more difficult than usual).
Issue
Black boxes covering 80% of the view window. Sometimes covers the icons too. Sometimes the icons and file/edit/etc goes blank. This lasts for about 10 seconds and occurs every couple of minutes or so. I just guess where I'm clicking.
Same issue with both FreeCAD 0.18 and 0.19 pre release. Using 64bit.
Please see screenshot attached.
My machine
Windows Surface Laptop 3 13"
i7-1065G7
Iris Plus Graphics
16G RAM
Connected to external monitor
I've tried playing around with some of the preferences. Nothing has changed it.
I'm guessing it's a graphics driver issue.
Any suggestions? Should this be reported as a bug?
Thanks in advance.
Black boxes
Issue - Black Boxes.png (205.94 KiB) Viewed 112 times
Re: Black Boxes - Bug or Driver Issue?
Postby chrisb » Wed Oct 21, 2020 7:54 am
Moved to Help forum.
This looks indeed like a driver issue, and a ticket would not help much. Please have a look at the Known OS specific issues, perhaps there is something for you listed there.
jmaustpc
Postby jmaustpc » Wed Oct 21, 2020 11:19 am
You should try going back to FreeCAD default settings and confirm if the issue goes away or not , to do that rename your hidden FreeCAD directory and restart FreeCAD, it will then not find the config files and will then creat bew o es with all default values.
You have a modified FreeCAD gui so it makes sense to first test if it is related to the issue.
