What's wrong with this sketch?
garya
Postby garya » Fri Oct 23, 2020 12:22 pm
I can't get this sketch to pad, but can't figure out what's wrong with it.
I get the message "Failed to validate broken face".
Hints?
Bug_Rings.FCStd
(11.01 KiB) Downloaded 21 times
OS: FreeBSD 11.3-RELEASE-p12
Version: 0.18.0.18.4
Python version: 3.7.8
Qt version: 5.14.2
OCC version: 7.4.0.beta
Locale: C/Default (C)
drmacro
Re: What's wrong with this sketch?
Postby drmacro » Fri Oct 23, 2020 12:32 pm
Multiple concentric circles
There can only be one layer of nesting of sketch geometry.
Overlapping geometry.
No Tee intersections allowed (created by the lines crossing the circle/s circumference).
My beginners, written treatise: Learning FreeCAD
GeneFC
Postby GeneFC » Fri Oct 23, 2020 2:35 pm
The key here is, "What should happen if FreeCAD was perfect in every respect?"
My "wetware" cannot figure out what you expect from all of those elements in the sketch. :?
Gene
ianj001
Postby ianj001 » Fri Oct 23, 2020 5:29 pm
What was the outcome supposed to be? - There are many issues with the sketch. It's not possible to work out what the pad should look like. It also appeared to have several overlapping lines that were not functional.
garya
Postby garya » Fri Oct 23, 2020 6:36 pm
Thanks all for the replies. The goal was to have thin concentric cylinders to serve as supports for printing another object. I know I can't have disjoint geometry, so I joined them with a horizontal bar. I now realize I have to take out the parts of the horizontal bar that just cross the cylinders, and make the two middle circles arcs that connect with the horizontal bar; I was thinking of a boolean union when I drew it.
drmacro
Postby drmacro » Fri Oct 23, 2020 6:39 pm
Thanks all for the replies. The goal was to have thin concentric cylinders to serve as supports for printing another object. I know I can't have disjoint geometry, so I joined them with a horizontal bar. I now realize I have to take out the parts of the horizontal bar that just cross the cylinders; I was thinking of a boolean union when I drew it.
You have to take out at least two of the circles as well.
garya
Postby garya » Fri Oct 23, 2020 7:06 pm
[/quote]
[/quote]
Thanks, I discovered that while fixing it (converted them to arcs).
