Hi all,
I am trying to create a counterbored hole in the attached part, but somehow it doesn't work. When I click OK to confim the hole parameters, FreeCad just returns to the holes I had before. It looks like the value of the "Hole Cut Type" (none,counterbore,countersink) doesn't get transferred to the model. When I change the Hole Cut Type manually, it does retain the value.
Is this a bug or am I doing something wrong?
Jordy
FreeCad:
OS: Windows 10 (10.0)
Version: 0.19.22756 (Git)
Hash: ce87f586ee36ffe8ebcdcd3947ced4ab389ae795
Python version: 3.8.6
Qt version: 5.12.5
Coin version: 4.0.0
OCC version: 7.4.0
[Solved] Counterbored hole bug
- block.FCStd
- (22.54 KiB) Downloaded 32 times
Re: How do I create a counterbored hole?
Follow my tutorial...where I use a counterbored hole as part of the tutorial...and show two different approaches...
https://github.com/macdroid53/LearningFreeCAD
Thank you very much!!! I searched for an answer, but did not find that thread.FCuser2019 wrote: ↑Fri Oct 23, 2020 1:08 pm Yes, it is a bug https://forum.freecadweb.org/viewtopic.php?f=3&t=50680
Workaround is to set the hole type in the parameters after confirming.
