About thickness problem???
xsuper9988
Postby xsuper9988 » Sat Oct 24, 2020 4:29 am
I cant thickness on this file (999.step)
But i can thickness it on Fusion360
Can anyone help me , thank you very much.
My Ver
FreeCAD_0.19.22808_Win-LPv12.1.6_vc14.x-x86-64.7z
My test file
https://github.com/xsuper9988/Freecad-t ... n/999.step
Re: About thickness problem???
Postby chrisb » Sat Oct 24, 2020 5:00 am
Hi and welcome to the forum!
Thickness is one of the most picky functions in FreeCAD. It comes from the third party geometric kernel, FreeCAD can't do much about it.
The easiest way would be to apply thickness in Fusion and export that. In FreeCAD you can model the inner part and subtract it with a boolean cut.
jmaustpc
Postby jmaustpc » Sat Oct 24, 2020 10:25 am
It fails a Part Workbench Check Geometry test. So a thickness or any other operation is likely to fail.
I don't know why this was posted to the Install/compile forum, so I moved it to this Help forum.
xsuper9988
Postby xsuper9988 » Sat Oct 24, 2020 3:43 pm
"Part Workbench Check Geometry test"???
How can i to do this?
Roy_043
Postby Roy_043 » Sat Oct 24, 2020 4:15 pm
Part_CheckGeometry
xsuper9988
Postby xsuper9988 » Sun Oct 25, 2020 10:27 am
I test "Part Workbench Check Geometry test"...
999.step is many errors...
and 999.FCStd is no errors...
but 999.FCStd still cant use thickness successful...
FredOP
Postby FredOP » Sun Oct 25, 2020 11:51 am
Is this a one off need, or is it just a part of a larger workflow, meaning .. you'll have the same problem later again, and you can't do anything about it
Also, assuming you can get thickness working, what is the next step for this object ?
xsuper9988
Postby xsuper9988 » Tue Oct 27, 2020 3:05 am
Its just a part of a larger workflow
So i use Freecad and Fusion360 together
This is very troublesome
