bent sheet metal manufacturability problem
mfro
Re: bent sheet metal manufacturability problem
Post by mfro »
chrisb wrote: Mon Oct 26, 2020 7:24 am I am not at all familiar with OpenSCAD, but there is an import format *.csg for OpenSCAD files. Can you export into that format? Hopeully it is not lossy as stl is.
*.csg is something different, I believe.
OpenSCAD (*.scad) files *can* be imported: https://wiki.freecadweb.org/Import_OpenSCAD_code (provided you have the application installed and follow the instructions in the link).
This will not help much, however, I'm afraid. The radii still appear to be ragged somehow:
Bildschirmfoto von 2020-10-26 12-59-44.png (2.35 KiB) Viewed 498 times
But someone with more patience than me might be able to delete and recreate them in FreeCAD.
Cheers,
Markus
Internet4ever
Post by Internet4ever »
Thanks to all contributors! I'm going to have a look at the sheetmetal workbench.I did not expect that the rack panel can be unfolded, because of the facetted bends.
Internet4ever
Thank you @papyblaise! More than a year has passed w/o me working on the project anymore. I'll be using your kind example to proceed.
papyblaise
Post by papyblaise »
we find the same problem here https://forum.freecadweb.org/viewtopic. ... 30#p551252
the folding and unfolding protocol changes from one software to another, which makes them incompatible
