Select face by expression
FredOP
Post by FredOP »
Is there a notion in FreeCAD of using some code to selection faces and edges, rather than by name ?
Coming from SideFX Houdini, I'm used to just throw some code in a point wrangle when I need a feature that doesn't exist, and I'm looking for something that feels that way in FreeCAD.
Re: Select face by expression
You can throw in some Python code in the Python console.
FredOP
Post by FredOP »
chrisb wrote: Thu Oct 29, 2020 11:19 am You can throw in some Python code in the Python console.
But this would be executed just once ?
openBrain
Post by openBrain »
Can you try to better explain what exactly you're trying to achieve? Ideally give an example.
jmaustpc
Post by jmaustpc »
FredOP wrote: Thu Oct 29, 2020 1:09 pm
You can save any Python code as a macro, see the FreeCAD macro tool
Like openbrain said,explain what you mean. Your post doesn't make sense at least not to me.
FredOP
Post by FredOP »
openBrain wrote: Thu Oct 29, 2020 1:11 pm Can you try to better explain what exactly you're trying to achieve? Ideally give an example.
Select the faces which normal is parallel to a given direction within a certain angular deviation.
Pad them.
openBrain
Post by openBrain »
FredOP wrote: Thu Oct 29, 2020 1:22 pm Select the faces which normal is parallel to a given direction within a certain angular deviation.
Pad them.
You can write a macro that will take as input a selected edge, compute all face normals, check which one are in a defined deviation tolerance, and extrude them. Just a bit of Python, maths and FC API. ;)
FredOP
Post by FredOP »
openBrain wrote: Thu Oct 29, 2020 1:32 pm
Pad them.
Can a macro be executed at a certain point in the workflow, like any other feature ?
Pad them.
Your explanation is still rather short. Do you want to perform the select via code? And how is the direction given? And how do you provide the angular deviation?
Please note that we have absolutely no idea what you are modeling, what you want to have in the end, and I dare to say, most people here don't know SideFX Houdini. At least the name sounds like a magician's trick.
openBrain
Post by openBrain »
FredOP wrote: Thu Oct 29, 2020 1:43 pm Can a macro be executed at a certain point in the workflow, like any other feature ?
Sort of. You can create a so-called 'scripted object' that will appear in the tree as a feature and define a specific behavior.
In your case looks possible to have such an object with a property holding the edge defining the direction, and another one a list of child objects (and eventually another for deviation tolerance, another for extrude length,...) and implementing your wanted behavior.
