Problem performing boolean between additive loft and pad
falviani
Postby falviani » Sun Nov 01, 2020 7:02 pm
Hello All,
Here is my setup:
OS: Windows 10 (10.0)
Version: 0.19.22865 (Git)
Hash: 3c307b7a3c222d66cb70695cdcf79606553fcb91
Python version: 3.6.8
Qt version: 5.12.1
I have a model where I need to perform a boolean between an additive loft and a pad, to remove part of the loft (as shown):
My problem is that I can only select 1 node in the tree at a time, so I can't perform the operation (file is attached). Could anybody explain what's going on so I can correct the problem?
Thanks in advance,
Frank Alviani
HeelAttachmentV6_heelonly.FCStd
(108.22 KiB) Downloaded 8 times
drmacro
Re: Problem performing boolean between additive loft and pad
Postby drmacro » Sun Nov 01, 2020 7:08 pm
In Part Design the last feature in the tree (in this case Pad) is the cumulative result of all previous operations.
Thus what you see IS the current state of the solid. I.e. the loft is part of the Pad. So, you can't select the loft to remove from itself, so to speak.
In addition Sketch008 and 009 are not attached to anything. (though nothing to do with the your problem.)
HeelAttachmentV6_heelonly-mac.FCStd
(153.79 KiB) Downloaded 4 times
My beginners, written treatise: Learning FreeCAD
Roy_043
Postby Roy_043 » Sun Nov 01, 2020 7:12 pm
Shouldn't the last Pad be a Pocket instead?
