photogrammetry to CAD
thschrader
Postby thschrader » Sat Nov 07, 2020 9:23 am
From the customer we get a photogrammetry-scan (with a drone) of a radio-tower.
The file is a 957 MB obj-mesh (including material/picture files).
Order: use the existing mesh as construction-reference for additional steel-parts.
With cloudcompare/FreeCAD I can reduce the mesh to the relevant part.
But the mesh is far to rough. From a previous project at this tower I know the dimensions
of some steel parts. When making an overlay with the mesh, you can see that the scan cant
be used for further work. I used “instantmesh” to produce a quad-mesh. Looks more
detailed, but doesnt help. The computation is RAM-intensive, at minimum 16 GB RAM necessary.
My solution would be to do an additional drone-run with a much higher resolution.
Which means I must fly near by the frame, above the platform, without seeing the drone.
Has anybody experience with such projects?
What drone/camera would you suggest?
Is a predefined/automatic flight possible (I am not a pilot)?
I need a scan-resolution of 5 mm minimum. Is that possible?
Comments welcome
frame.FCStd
(614.73 KiB) Downloaded 22 times
https://github.com/wjakob/instant-meshes
http://www.danielgm.net/cc/release/
saso
Re: photogrammetry to CAD
Postby saso » Sat Nov 07, 2020 9:41 am
You would probably need a laser scan for such high precisions... And if you need it just for reference why using the mesh, why not just the point could?
Willem
Postby Willem » Sat Nov 07, 2020 9:55 am
A while ago there was someone using photogrammetry for reconstruction a historical racing boat. See https://forum.freecadweb.org/viewtopic.php?t=27770
thschrader
Postby thschrader » Sat Nov 07, 2020 5:12 pm
I agree, good point.
At the moment we only get the mesh from the customer.
But there must exist the point cloud as a base for the meshing.
The images from the radio-tower are analized via this portal,
which gives back the obj-mesh (and some other stuff...)
https://www.vhive.ai/telecommunications/
I played a little bit with COLMAP and my cellphone (as a camera).
https://colmap.github.io/
jeno
Postby jeno » Sun Nov 08, 2020 8:02 am
Are you looking for this?
Regards
frame.zip
zipped xyz point cloud file
(254.67 KiB) Downloaded 12 times
thschrader
Postby thschrader » Mon Nov 09, 2020 2:53 pm
Yes, thanks a lot.
You can use the points for measurement, with arch-wb, line-tool.
I wonder how you created a real point object. I part-wb I selected the obj-mesh in the
tree and used "Create points object from mesh" (the black points).
But export as asc-file gives an error:
'Tile_1_nur_Mast_pts' is not a point object, export will be ignored.
This week our customer gives me an account for the vHive-portal (and a drone :) :o ).
I will try to get/generate a more precise mesh/point-cloud.
Site Admin
Postby wmayer » Mon Nov 09, 2020 3:10 pm
That's the wrong function because it creates a shape with vertexes. You have to switch to the Points workbench and use the function there.
jeno
Postby jeno » Tue Nov 10, 2020 6:12 am
Yes, thanks a lot.
I wonder how you created a real point object....
Hi Thomas,
I saved the mesh with the help of the mesh workbench as stl. I opened it in meshlab and saved the vertices of the mesh as xyz file.
Kind regards
Site Admin
Postby wmayer » Tue Nov 10, 2020 7:15 am
As said you can do the same with the function "Convert to points" in the Points wb. When invoking it a dialog comes up asking for the maximum distance and here you can enter any value because for a mesh its vertices are used (no sub-sampling is done).
The advantage of this function is that it also delivers a normal per point which might be useful in the further post-processing. You can see the existence of the normals when you set the display mode to Shaded because then you get almost the same visual representation as with a mesh.
When you export the point cloud and want to keep the normals then use the formats PLY or PCD.
thschrader
Postby thschrader » Sat Nov 21, 2020 5:17 pm
How to scale a point object?
Treestump has ca. 60 cm diameter in reality, cube size 2 mm!
Photogrammetry:
60 images with cellphone around stump, ply-file (100 MB) generated with visualSFM
and imported in FC and Cloudcompare.
http://ccwu.me/vsfm/
Goal: scan steel-structures, import in FC as design-reference for additional parts.
I have done this to find a workflow.
Advice welcome. Especially about the general precision of photogrammetry.
