Postby freedman » Thu Nov 12, 2020 2:11 am
Geez, thanks Mario52. Very helpful...
The reason behind the toolbar follows in the pics. Each pic shows Sketch mode 1 (SM1) on the left and Sketch mode 2 (SM2) on the right.
Just about every time I get a file off the forum I convert the file to SM2 format, it allows me to see where the sketches are placed relative to the model. Also, I have been using SM2 for about 2 years, I get to design and see the entire model.
The problom with SM2 is the fact that you can't see sketches imbeded in the model so most everyone uses (SM1), the FreeCAD default. If we can change the global transparency easily then we all can start using SM2.
I think it's easy to see that SM2 is a better format for modeling.
To refresh what SM1, SM2 look like (in 0.19).
SM1 = Edit-Preferences-Sketcher-Display-Check box "Hide all objects that depend on the sketch" is checked.
SM2 = Edit-Preferences-Sketcher-Display-Check box "Hide all objects that depend on the sketch" is unchecked.
You will need to "Apply to existing sketch".
- SM1_SM2_sketch.png (275.85 KiB) Viewed 178 times
- SM1_SM2_sketch1.png (193.43 KiB) Viewed 178 times
- SM1_SM2_sketch2.png (210.69 KiB) Viewed 244 times
- SM1_SM2_sketch3.png (215.66 KiB) Viewed 244 times
- SM1_SM2_sketch4.png (188.28 KiB) Viewed 244 times
freedman on Fri Nov 13, 2020 7:31 pm, edited 3 times in total.
