Rename: The two visual modes of using Sketcher
freedman
Postby freedman » Sun Nov 08, 2020 8:24 pm
I'm having a tough time searching for how to make a standard toolbar, like one that could be put in Master at some point. Is there a template or some sample code? I search and most all I get is how to install or modify in the program. Just doing a little research.
Thank you
openBrain
Re: How to make a standard toolbar
Postby openBrain » Sun Nov 08, 2020 8:53 pm
Are you looking for Python or C++?
freedman
Postby freedman » Sun Nov 08, 2020 9:34 pm
Python. My thoughts were to get everything working in a macro then let you folks review and tear it up, to get it right. :) and then migrate to a toolbar. I would expect to build some icons (again for review), I don't know how this all packages but I would hope to get 95% of the work finished and then someone can try to integrate. I don't see me compiling FreeCAD currently.
Thanks
johnwang
Postby johnwang » Mon Nov 09, 2020 1:30 am
You could try to download my test workbench. https://forum.freecadweb.org/viewtopic.php?f=40&t=44893
Just unzip under yourFreeCAD/mod folder. Start FreeCAD, switch to that hpBox workbench. You could add your code on it.
mario52
Postby mario52 » Mon Nov 09, 2020 12:33 pm
hi
also here (macro) cube menu addon, please with icon include in macro
or Customize_Toolbars
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Topological_data_scripting, Dialog creation. My macros on Gist.github.
freedman
Postby freedman » Tue Nov 10, 2020 5:14 am
Thanks all. That should do it.
Here is my target, I put together a 5 minute quick pic so you get the idea.
The first icon associates directly with (on v0.19) the setting Edit-Preferences-Sketcher-Display-Check box "Hide all objects that depend on the sketch". The button is a toggle SM1-SM2, SM2-SM1, the text stands for Sketch Mode 1 and 2. The button when set to SM2 needs to set the check box and set the option "Apply to existing sketches".
I don't know how to apply "Apply to existing sketches" in code, I don't know if it's ever been done.
The next three buttons set the global visibility (all objects) to the shown transparency.
I will do a following post showing why I think this setting is one of the most important changes FreeCAD can make.
Obviously the SM1-SM2 could turn into a series, SM3,SM4......
Thanks
drmacro
Postby drmacro » Tue Nov 10, 2020 11:02 am
hmm...I'm on a tablet at the moment, so can't check. But, I seem to remember someone else offering a macro or menu to do the transparency thing.
and "one of the most important changes"...count me as dubious 8-) but I look forward to you explanation.
My beginners, written treatise: Learning FreeCAD
mario52
Postby mario52 » Wed Nov 11, 2020 7:23 pm
hi
@ freedman i adapt my macro try this
Visibility_ToolBar.zip
(6.21 KiB) Downloaded 6 times
you must modify the values in the Edit parameter after the first use
User parameter:BaseApp/Preferences/Macros/FCMmacros/Visibility_ToolBar
mario
freedman
Postby freedman » Thu Nov 12, 2020 2:11 am
Geez, thanks Mario52. Very helpful...
The reason behind the toolbar follows in the pics. Each pic shows Sketch mode 1 (SM1) on the left and Sketch mode 2 (SM2) on the right.
Just about every time I get a file off the forum I convert the file to SM2 format, it allows me to see where the sketches are placed relative to the model. Also, I have been using SM2 for about 2 years, I get to design and see the entire model.
The problom with SM2 is the fact that you can't see sketches imbeded in the model so most everyone uses (SM1), the FreeCAD default. If we can change the global transparency easily then we all can start using SM2.
I think it's easy to see that SM2 is a better format for modeling.
To refresh what SM1, SM2 look like (in 0.19).
SM1 = Edit-Preferences-Sketcher-Display-Check box "Hide all objects that depend on the sketch" is checked.
SM2 = Edit-Preferences-Sketcher-Display-Check box "Hide all objects that depend on the sketch" is unchecked.
You will need to "Apply to existing sketch".
freedman
Postby freedman » Thu Nov 12, 2020 2:13 am
Here is the model file for the previous post, the file got too big.
Test_arch_block.FCStd
(206.05 KiB) Downloaded 2 times
