Postby freedman » Sun Nov 15, 2020 6:20 am
Since I got this working I thought I would at least post the fix in a macro. It works great and updates correctly in Preferences.
The SM1 button toggles between SM1 and SM2. When using SM2 the model will be shown solid (in Sketcher) until you use the global visibilty buttons to peer thru the surface. If you load a new document you will need to toggle the the SM button to apply settings, the macro does not react to a new file load.
There is still some work to be done to get this into a toolbar.
I added a pic of ppemawm's Grinder, a huge difference if your trying to design in context. SM1 on the left, SM2 on the right.
- Grinder_SM1_SM2.png (263.88 KiB) Viewed 153 times
Vision_SM1_SM2.FCMacro
- (4.4 KiB) Downloaded 12 times
- sm1_2_pic.PNG (2.78 KiB) Viewed 188 times
freedman on Tue Nov 17, 2020 11:45 pm, edited 1 time in total.
