Importing from FreeShip to be used by FEM?
Re: Importing from FreeShip to be used by FEM?
ok, yes. I forgot to lock the pad lock.
... I had also problems with the points cloud.
You can get it from test.stl via "display only points" and from test.asc via import.
But if I tried to connect these points by CurvesWB "Interpolation_Curve" they don't get green.
I also had repeatedly de- and activated "selectable" in the points property - no success.
Only DraftWB is able to snap them???
FC.18.4 Win32
FC.18.4 Win32
Thank you all for the great help. Now I cannot do FEM analysis at all (made another topic out of that), but I remember that Part/Create shape from mesh did work.
I had to add a plate thickness though, because the mesh is a surface mesh.
I still cannot edit, but that will be another question.
And yes, the ship is miniature, because Freeship uses meter as base unit, while freecad uses mm. I can scale it up either in Freeship or freecad.
Thanks again!
Thanks again!
... I supposed the boat should be a hard chined boat and scaled it up to 12m.
Planking 50mm (or less). From Ruled_Surface planking I made a PartWB fusion.
File is too big for presenting here (1500kB).
That is a bit more tedious than Part/create shape from mesh, but solves the problem of multiple shell thicknesses.
Thank you.
( Freeship actually uses subdivision surfaces, which makes plate development possible. This is a minor point, as I don't think a bspline is so different as to meaningfully alter the FEM results (a ship should be considerably overbuilt after all). Just out of curiosity, is there a way in Freecad to accurately modell developable surfaces? I'm just fascinated by stitch&glue and steel origami building techniques.)
... unfolding = plate development?
In FC there are unfolding tools => especially unfolding mesh.
https://forum.freecadweb.org/viewtopic. ... 85#p223479
With my FC.18.4 under Win10_32bit I can't do that.
There a macro to unroll surface as well:
https://wiki.freecadweb.org/Macro_Unroll_Ruled_Surface
Result should be compared with mesh unwrap.
Nice work hammax, do you get constant plate thickness when using surface offset this way? I have a vague memory from the distant past in tinkering with fc and shape/surface offsets that I had to give up at that time on constant thickness for multiple curvature surfaces.
Well, getting the fem running with a shell model turned out to be a rabbit hole, some of the sharp corners in fc is certainly not for the fainthearted , but hang in there and you will get rewarded.
Took a while but finally got there. it’s just a test condition to sort out the workflow, here shown with exaggerated displacement to see that it behaves as expected.
Here is the crooked path on linux that is behind the above picture.
It should not be too hard to add more realistic framing as surfaces, allowing one to do a fully usable structural check on a realistic hull.
Fc, as always turns out to be versatile, but it does require a bit of patience to get it to play along.
Would not be surprised if it with scripting is possible to go from hull lines as dxf or point cloud to viewable fem result with only 2 user interactions, the first would be to pick a file, the other one would be to pick the uppermost point of the bow (well assuming that you’re ok with doing it without additional framing).
- First did the fem setup as any tutorial, keeping in mind that one has to add the shell element thickness as an extra step (which is easy to spot from the fem menu).
- In the snap fc v18 install gsmh is not included, and I could not get that hooked up with fc, does not matter so much since netgen works just fine on shells as long as one settles for triangular meshing. Actually could not even get the external ccx hooked up with fc, although it is clearly there and usable.
- Ran the analysis – error. The error was node limit exceeded – there has to be something funny going on with how ccx is included in fc in this snap.
- Did a small test model to check the workflow, worked just fine – so why did it not work on the hull then?
- Small side note, when using shells in ccx, ccx will expand it to a full 3d prism (like thickening the face) for the matrix assembly. The default setting in fc is to only bring back the “reduced” shell result. Flipping that switch in fc, one can view the actual calculated 3d-mesh also in fc.
- Back to the hull and fiddling with linear elements and half hull variants. That got me under the node limit, but sadly just changed the error code, which was now in node dependencies. Changes in the model and the node it got stuck on shifted.
- Decided to try directly with ccx, did the apt install calculix-ccx (which for whatever reason installed v2.11 which I gather is quite old), took the input deck from fc and the job completed successfully – go and figure...
- So now I have a result file that I cannot view… back to apt install calculix-cgx and trying to figure out how to view results there. Managed to load something so that one could see that there was coloring. One step closer, we now have what seems to be an ok result file.
- Now, fc uses ccx, so how to get a loose .frd back into fc so that one can view the results there? Turns out that one can simply import a .frd file, great. Although, just importing it does not make it viewable from the fem wb. One also has to move the results into the Analysis group in the tree (can be done via draft/utils, or a right-click on the results in the tree-view).
- Finally there
Nice job heda.
For fea, always use the latest FC version. https://github.com/FreeCAD/FreeCAD/rele ... g/0.19_pre
Scroll down to the bottom, download from the Assets section.
Just wondering what kind of loads and constrains are applied?
Thanks
John
... converting the hull to a rounded (BSpline) Form:
Offset is possible on a Gordon shell - but it is a little bit kinky near the bow.
It is able to cut off this region by a cube and place there a round bow.
The Gordon surface gives a nice mesh under Mefisto and 200mm max. edge length.
I only can supply the preliminary frames for CurvesWB Gordon, the file afterwards goes over 1Mb.
I think 3D-Offset is performed orthogonally/normal to the local surface and has equal thickness.
Only at complex shape transitions there could be a distortion (my experiences till now).
- PointsMeshHull_3.FCStd
- FC.18.4
- (750.28 KiB) Downloaded 25 times
