CRMS wrote: ↑Mon Nov 23, 2020 8:26 am
Yes, understand inside/outside depending on sketcher used.
But why choose one way over the other?? What is the benefit of each??
Its as simple as this, if you are PartDesign workbench then the sketch must be inside a body, but sketches can be used in many official and add-on workbenches, where most will not use the Body object.
As openbrain said, there is Part WB but also Arch wb, surfaces WB, etc., these other workbenches can have many different work flows and use the sketches for different things and in different ways.
