Use length of a sketch line in an expression
I would like to use the length of a line in a sketch in an expression.
I have had success using expressions to reference aliases in spreadsheets.
but i dont know how to reference a specific lines length from a sketch
<<Sketch>>.Constraints seems to show up in the formula builder but i cant access the sketch elements
also is it possible to create an alias for a sketch element such as a line?
looking for an alternative method i also cannot find a suitable tool to create a measurement between 2 end points of a line in a sketch, std measure is greyed out.
thanks
thanks
Re: Use length of a sketch line in an expression
Like this ?
- Reference.gif (652.53 KiB) Viewed 2933 times
wow thank you for your time creating this giff. Yes this is the method i have discovered, aditionally selecting the reference checkbox when creating the sketch constraint makes it a dynamic constraint (measurement) that gets overridden by other constraints.
It's a pleasure to see a newbie helping with such high quality!
A note for slightly speeding up such sketching: You don't need to select the endpoints in this case, you can simply select the line.
Still curious though about referencing a lines length directly without the creation of a constraint.
You need at least what is called a "driven constraint". In 0.19 you can check the box "Reference" when creating the constraint or toggle it later. Such constraints are shown in blue.teejay03830 wrote: ↑Sat Nov 28, 2020 5:44 pm Still curious though about referencing a lines length directly without the creation of a constraint.
You can do thatteejay03830 wrote: ↑Sat Nov 28, 2020 5:44 pm Still curious though about referencing a lines length directly without the creation of a constraint.
<<mySketch>>.Shape.Edge1.Length
Will give you the length of a line in your sketch. Just try Edge2, Edge3 and so on to find out which one is the one you are looking for.
Another method
If the line you are looking for is used to draw a shape then you can select the edge drawn using your line and refer to it, which will give the same value as your line. You can select the edge and use a ready made macro like the FCInfo to see the name of the edge you have selected, or try out different name numbers like in the previous method.
<<myShape>>.Shape.Edge9.Length
Note that the edge names turn out to be different for each method.
Also note that you need to start the address parts with capital letters.
greetings
Asker
Asker
You should avoid that if possible as it breaks very easily on sketch changes. References are much more robust.
Cheers,
Markus
Markus
Sure, but the forum member asked specifically for that where you access data without having to name elements or creating constraints first.
I am using the method to pull out measurements into tables but not to drive sketches from tables.
greetings
Asker
Asker
There are a selection window that shows wat you are selected in case you need a line name in sketch and on 3d object
