Exception during draw: Sketch::checkGeoId. GeoId index out range.
leoheck
Post by leoheck »
I have one Part Design Body that was good and now it is not being displayed. I haven't touched it for a while and I am trying to investigate what is causing this.
I am seeing this, maybe it is related. What does this exception mean?
21:24:27  Exception during draw: Sketch::checkGeoId. GeoId index out range.
OS: Ubuntu 20.04.1 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.
Branch: unknown
Hash: b920bbf73a594881a807f7d7cf056fbc1e99f53a
Python version: 3.8.5
Qt version: 5.12.8
Founder
Re: Exception during draw: Sketch::checkGeoId. GeoId index out range.
Post by wmayer »
Abdullah has changed quite a lot in Sketcher recently and it might be a regression.
abdullah wrote: ping
abdullah
Post by abdullah »
leoheck wrote: Wed Dec 16, 2020 12:34 am I have one Part Design Body that was good and now it is not being displayed. I haven't touched it for a while and I am trying to investigate what is causing this.
Version: 0.19.
Branch: unknown
Qt version: 5.12.8
May I get the offending sketch?
It is impossible to know what can be without it....
jmages
Post by jmages »
I have the same error message once in a while when working with sketcher. But it is not reproducible. By repeating the last action the message does not appear again.
OS: Windows 10 (10.0)
Version: 0.19.23258 (Git)
Hash: 78c6cc1362c39e3f1f778c52ae2a1c82badeec20
Python version: 3.8.6
Qt version: 5.12.5
OCC version: 7.4.0
abdullah
Post by abdullah »
This exception is thrown at ViewProviderSketch::draw, towards the middle-end of the very long function (line 5603). This draw() function is rather complex. It does something somewhere directly or indirectly calling the solver interface (sketch.cpp). This is the one generating the exception. My best guess is that the solver is not synchronised with SketchObject geometry. What causes it to be out of synchr is rather the bug (the root cause) and what needs to be investigated.
It is probably one line looking like:
getSketchObject()->getSolvedSketch()
probably:
getSketchObject()->getSolvedSketch().getPoint(
which internally calls the checkId() function.
jmages wrote: Wed Dec 16, 2020 1:22 pm I have the same error message once in a while when working with sketcher. But it is not reproducible. By repeating the last action the message does not appear again.
My hypothesis is that it gets back in sync. That exception is there to prevent the crashing, but to show something is not ok and should be fixed. Then it is important to be able to reproduce...
abdullah wrote: Wed Dec 16, 2020 1:02 pm ...
I get it if I edit the sketch "Handle1" in the file "Hose Handle.FCStd" attached to this post.
abdullah
Post by abdullah »
chrisb wrote: Wed Dec 16, 2020 5:23 pm
Thank you. This was very useful:
git commit 6c6f5e7fbffe5bd2c389839cfe1c2b08ffa5f194
leoheck
Post by leoheck »
abdullah wrote: Wed Dec 16, 2020 1:02 pm May I get the offending sketch?
Abdullah, sure, how do I know which is the offending Sketch?
Crisb was faster than me. Do you still need this Sketch?
Version: 0.19.
Branch: unknown
Hash: 51189caba41a97fe5cf6b65c5828341b23aefff3
Qt version: 5.12.8
abdullah
Post by abdullah »
leoheck wrote: Thu Dec 17, 2020 9:04 am
That exception should only happen when you have one Sketch in Edit mode.
In order to streamline the bug fixes, it is better if you could test if the fix is working for your sketch. If it is not, then definitely I would like to have the sketch to see what is happening in that other case.
leoheck
Post by leoheck »
Sure! The issue is that I don't know which Sketch is that one since I don't always look at the report view. But at least you gave one way to look for it. Opening each sketch until seeing that message.
