How to use Draft wb Fillet?
I tried use fillet in the draft wb with wires objects but do nothing...
Maybe is there a bug?
OS: Windows 10 (10.0)
Version: 0.19.23578 (Git)
Hash: 50c3cbf00579dc4941ca743c25720d016b0453ce
Python version: 3.8.6
Qt version: 5.12.5
OCC version: 7.4.0
Locale: Spanish/Peru (es_PE)
Qt version: 5.12.5
OCC version: 7.4.0
Re: How to use Draft wb Fillet?
What exactly did you do? Draft Fillet works different from Sketcher's fillet, and it doesn't work for polylines.
I was trying use it in polylines and exactly like sketcher.
Then how can I do it?
A Draft wire has a 'Fillet Radius' property.
Why can't you do it in Sketcher? Most functions taking a draft wire can use a sketch as well. If you really need a Draft object you can in Draft workbench convert a sketch.
yes, for the traditional FreeCAD objects you are right, but I wish to create a MEP workflow, this means than I need to use wire objects as 3D lines with Sweep command, well, at least is my first idea...
how the video shows, I tried to use Draft Fillet as the wiki documentation suggests, but fillets do nothing with 2 wires or edges.
then, how can I use fillet with wires?
- thomas-neemann
Hello again.
Is there any method to fillet only selected vertex without break Wire Object?
- thomas-neemann
if it's a solution for you, you could use draft to sketch to make a sketch out of it, add curves and draft to sketch back
