Partially redundant constraints
kisolre
Post by kisolre »
Recently sketcher reports Partially redundant constraints. I found that opening the sketch and checking report vied there is a message
22:10:10  Analysing groups of constraints of special interest:
[26 26 1 0 0 0 0 ]
22:10:10  Chosen redundants: [26 ]
and indeed No 26 (a symmetry) was partially redundant. But this is buried deep. Can we have a report in the solver messages about that?
abdullah wrote: ping
abdullah
Re: Partially redundant constraints
Post by abdullah »
kisolre wrote: Sun Jan 24, 2021 8:15 pm Recently sketcher reports Partially redundant constraints. I found that opening the sketch and checking report vied there is a message
[26 26 1 0 0 0 0 ]
I thought I had. Could you post here the offending sketch? (or give me a link to where this sketch is to be found)
kisolre
Post by kisolre »
abdullah wrote: Mon Jan 25, 2021 5:22 am Could you post here the offending sketch?
I already fixed those :-( But I will dig the backups later...
kisolre
Post by kisolre »
Here I extracted all of them. They all show redundant constraints in report view, none of them show the warning in solver messages (I saw it on occasion fixing them).
PartiallyRedundantConstraints.FCStd
(21.95 KiB) Downloaded 54 times
abdullah
Post by abdullah »
kisolre wrote: Mon Jan 25, 2021 1:47 pm
Indeed. Thank you. It is coded so that only shows the message if the sketch is not fully constrained (if you add one line, you will see the message). I will fix this today.
kisolre
Post by kisolre »
abdullah wrote: Tue Jan 26, 2021 7:28 am I will fix this today.
Thanks, works as expected now :)
Maybe a different color for the warning would be better. Now it looks like a serious error..
abdullah
Post by abdullah »
kisolre wrote: Tue Jan 26, 2021 11:11 am
shhh... do not wake Chrisb up... I'll change the color... :lol:
Which color should it be?
kisolre
Post by kisolre »
abdullah wrote: Tue Jan 26, 2021 3:47 pm Which color should it be?
No idea. But the color of the report view warnings looks like a good candidate. Not sure how readable will it be. Or some green one as "suggested improvement to your sketch" :)
abdullah wrote: Tue Jan 26, 2021 3:47 pm shhh... do not wake Chrisb up... I'll change the color... :lol:
And here I am, one eye is already open...
The color could be something orangeish, perhaps the same as for the warnings in report view?
abdullah
Post by abdullah »
chrisb wrote: Tue Jan 26, 2021 5:46 pm
I knew you were going to say that, so I anticipated:
Kilsore was suggesting to use something green... which I am sure you would not like. :lol:
