Dimension between two parallel lines
hic
Re: Dimension between two parallel lines
Post by hic »
Pauvres_honteux wrote: Sat Jul 03, 2021 8:57 pm Will you make a feature request for this?
Yes, I will :)
Pauvres_honteux
Post by Pauvres_honteux »
hic wrote: Sat Jul 03, 2021 9:35 pm Yes, I will :)
Wohoo! :P
Pauvres_honteux wrote: Sat Jul 03, 2021 8:57 pm If the lines aren't parallel (you automatically get an angle value) you just right-click and select "distance" and the lines magically becomes parallel !
Without such additional behaviour it wouldn't be stable at all, because one of the parallel lines could be rotated, making the distance constraint invalid.
hic
Post by hic »
hic
Post by hic »
To automatically generate a parallelism constraint could lead to problems if the lines are already constrained parallel in any other way, i.e. the sketch becomes over constrained.
Ideally there would be some intelligence that offers to automatically remove one of the conflicting constraints. But I think, the way that it works today would be sufficient - you get a warning and have to remove another constraint manually.
hic wrote: Sat Jul 03, 2021 10:24 pm Ideally there would be some intelligence that offers to automatically remove one of the conflicting constraints.
Let's not push it over the top and create completely new solver concepts. The issues with conflicting or redundant constraints are already there and are already dealt with.
Pauvres_honteux
Re: [Ticket #4700] Dimension between two parallel lines
hic wrote: Sat Jul 03, 2021 10:18 pm Link to bugtracker: issue #4700
Hi hic, would you mind prepend your headline of this thread with [Ticket #4700] ?
See how I did it in this post.
The edit button fo a post looks like a pen.
Post by Kunda1 »
ticket issue #4700 has moved to GH https://github.com/FreeCAD/FreeCAD/issues/6239
What's the consensus on this ticket?
Post by Kunda1 »
bump
Haavard
Post by Haavard »
I think @paddle has implemented this in "constrain contextual" amongst other things :)
