Has anyone had any success using the new render workbench on MacOS? I cannot seem to get any of the renderers working (macOS Catalina 10.15.7). I get the following:
- Appleseed continually asks permission to run libraries - you allow it and try again, and then it asks for another file, and finally says some files are damaged and won't open!
- I cannot compile the standalone Cycles renderer using their instructions - finally I get to:
/Documents/cycles/src/render/colorspace.cpp:207:16: error: no member named 'applyRGB' in
'OpenColorIO_v2_0::Processor'
08:57:47 /Applications/LuxCore.app -o "/var/folders/gc/kz6fvh1x6llcyhykn455_cjr0000gn/T/LuxcoreProjectkwv1z69b.cfg" -f "/var/folders/gc/kz6fvh1x6llcyhykn455_cjr0000gn/T/LuxcoreProject2c5ssfpe.scn"
08:57:47 LuxCore call failed: 'Permission denied'
09:18:16 Renderer command: /Applications/PovrayCommandLineMacV2/Povray37UnofficialMacCmd +P +A +W800 +H600 +O/var/folders/gc/kz6fvh1x6llcyhykn455_cjr0000gn/T/FreeCAD_Doc_2904492f-5719-4fc2-85ee-2d89a6ed1904_da39a3_41133/PovrayProject8b3kzgz_.png /var/folders/gc/kz6fvh1x6llcyhykn455_cjr0000gn/T/FreeCAD_Doc_2904492f-5719-4fc2-85ee-2d89a6ed1904_da39a3_41133/PovrayProject8b3kzgz_.pov
09:18:16 Running the Python command 'Render' failed:
File "/Users/me/Library/Preferences/FreeCAD/Mod/Render/Render.py", line 1031, in Activated
project.Proxy.render()
File "/Users/me/Library/Preferences/FreeCAD/Mod/Render/Render.py", line 581, in render
ImageGui.open(img)
Could not load image file
Thanks,
Brutha
OS: macOS 10.15
Version: 0.19.23756 (Git)
Hash: 9c6e9184930a52b165a0b7274e3a45d1006bfe67
Python version: 3.8.6
Qt version: 5.12.5
OCC version: 7.4.0
Locale: C/Default (C)
