[PD] two bugs when creating a multi-transform feature
Site Admin
Re: [PD] two bugs when creating a multi-transform feature
Post by wmayer »
uwestoehr wrote: Sat Feb 27, 2021 6:36 pm In the fresh FC 0.19 release I encounter two bugs with multi-transform features:
Bug A
1. select e.g. a Pad
2. add a multi-transform feature to it
3. add in the transform dialog a transformation of your choice, e.g. a scaled transformation
result: the transformation succeeded but you suddenly see nothing anymore in the model view
Compared to v0.18 this is a regression. But as soon as you press the OK button of the sub-dialog the object is back.
Bug B:
4. Cancel the multi-transform dialog
result: the operation is not canceled but you end up with 2 orphaned new features in the model tree
It's a slight regression to v0.18 and probably caused by opening a new transaction. But also v0.18 didn't work correctly here because it leaves an empty MultiTransform object.
OK to file bug reports?
Sure.
uwestoehr
Post by uwestoehr »
wmayer wrote: Sun Feb 28, 2021 11:54 am Compared to v0.18 this is a regression. But as soon as you press the OK button of the sub-dialog the object is back.
Here is a possible fix: https://github.com/FreeCAD/FreeCAD/pull/4542
Yes, after pressing OK you see the result, but the idea of a multi-transformation is to have several transformations within the same dialog. Therefore when no seeing the result of the first one, it is hard to go on and add the next. Having the result shown is therefore in my opinion mandatory.
I reported this now as issue #4582
Site Admin
Post by wmayer »
uwestoehr wrote: Mon Mar 01, 2021 1:34 am
Btw, the regression is caused by git commit 11a93a0578816b. It probably makes sense to always hide all existing features in a body when adding a new feature. However, multi-transform features are an exception because they are the parent of the transform features and making them invisible automatically makes their children invisible.
