Create 3D text on curved surface
andre
Postby andre » Sat Feb 15, 2014 2:19 am
Any quick tips on how to get this done? I'm Ok with creating planar text and extruding via Draft , then Part tool bench. Would like to create something like a wrist band with a name on it.
andre
Re: Create 3D text on curved surface
Postby andre » Sat Feb 15, 2014 5:43 pm
To add, is there a similar function to wrap a sketch onto a curved surface? Similar to how Solidworks handles this
ulrich1a
Postby ulrich1a » Sat Feb 15, 2014 7:53 pm
Is this post a possible solution?
viewtopic.php?f=3&t=5360#p42769
Ulrich
andre
Postby andre » Sat Feb 15, 2014 9:38 pm
I'll give it a try, thanks for the link.
My current version does not have make...Projection. Seems this may be a newer build/commit. I'm on 2778 unfortunately.
"AttributeError: 'Part.TopoShape' object has no attribute 'makeCylindricalProjection'"
OS: Windows 7
Platform: 64-bit
Version: 0.14.2778 (Git)
Hash: 0506a918b24e015ac6277a7cf613ce151e1dee44
Python version: 2.6.4
Qt version: 4.5.3
Coin version: 2.4.5a
SoQt version: 1.4.1
OCC version: 6.3.0
wandererfan
Postby wandererfan » Sun Feb 16, 2014 2:48 pm
andre wrote:"AttributeError: 'Part.TopoShape' object has no attribute 'makeCylindricalProjection'"
try "makeParallelProjection" ?
andre
Postby andre » Mon Feb 17, 2014 1:13 am
I don't have any make***Projection listed for the function...
NormandC
Postby NormandC » Mon Feb 17, 2014 2:28 am
wandererfan, check Andre's version in his third reply. Revision 2778 is pretty old and predates wmayer's commit which was added in January.
andre
Postby andre » Mon Feb 17, 2014 4:30 am
The January commit hasn't been compiled/released for win64 yet correct? I don't have access to compile the latest master branch, rather would be easier to just pick the latest available release. Seems like 2778 is the latest version downloadable at the moment.
NormandC
Postby NormandC » Mon Feb 17, 2014 4:54 am
normandc wrote:Revision 2778 is pretty old and predates wmayer's commit
There is no other Windows version more recent.
mangtronix
Postby mangtronix » Fri Jul 25, 2014 2:09 pm
I'm also trying to put extruded text around a 3D surface (a cylinder, to start).
Here's as far as I got:
https://gist.github.com/mangtronix/0b5010766d105874a3d5
import Part, Draft
from FreeCAD import Base
v=Base.Vector
doc=App.ActiveDocument
font="/Users/mangtronix/src/blender/release/datafiles/bfont.ttf"
# ShapeString text
ss=Draft.makeShapeString(String=u"Hi",FontFile=font,Size=2.0,Tracking=0)
# Circle at text center
c=Part.makeCircle(2,ss.Shape.BoundBox.Center,v(0,0,1))
s=Part.makeCylinder(4,10, v(1,-3,-10), v(0,1,0))
f=s.Face1
p=f.makeParallelProjection(c,v(0,0,1))
sf = doc.addObject("Part::Feature","Cylinder")
sf.Shape = s
pf = doc.addObject("Part::Feature","Circle projection")
pf.Shape = p
cf = doc.addObject("Part::Feature","Circle")
cf.Shape = c
sp=None
try:
    sp=f.makeParallelProjection(ss.Shape,v(0,0,1))
    # XXX this generates this traceback
    # Traceback (most recent call last):
    #   File "<input>", line 1, in <module>
    # Exception: /Users/family/FreeCAD-deps/oce-src/src/BRepProj/BRepProj_Projection.cxx: projected shape is neither wire nor edge
    spf = App.ActiveDocument.addObject("Part::Feature", "Text projection")
    spf.Shape = sp
except Exception,e:
    FreeCAD.Console.PrintWarning(e)
def projectAndFuseWires(face, shape, dir):
    projected_wires = []
    for wire in shape.Wires:
        projected_wires.append(face.makeParallelProjection(wire, dir))
    fused = projected_wires[0]
    for wire in projected_wires[1:]:
        fused = fused.fuse(wire)
    return fused
fused = projectAndFuseWires(s, ss.Shape, v(0,0,1))
fused_feature = doc.addObject("Part::Feature", "Fused projections")
fused_feature.Shape = fused
h_wire = ss.Shape.Wires[0]
projected_wires = f.makeParallelProjection(h_wire,v(0,0,1))
front_projected_wire = projected_wires.Wires[1]
front_feature = doc.addObject("Part::Feature", "Front projected H")
front_feature.Shape = front_projected_wire
extrusion = doc.addObject("Part::Extrusion", "Extruded H")
extrusion.Base = front_feature
extrusion.Dir = v(0,0,1) # XXX doesn't actually make a solid
extrusion.Solid = True
I wasn't able to directly project the ShapeString Shape so I tried projecting each wire individually. I wasn't able to extrude a solid from the "Front projected H" shape. If anyone has some clues maybe I can get further :)
OS: Mac OS X
Word size: 64-bit
Version: 0.14.3703 (Git)
Branch: releases/FreeCAD-0-14
Hash: c6edd47334a3e6f209e493773093db2b9b4f0e40
Python version: 2.7.5
Qt version: 4.8.6
Coin version: 3.1.3
SoQt version: 1.5.0
OCC version: 6.7.0
Screen Shot 2014-07-25 at 4.04.33 PM.png (23.16 KiB) Viewed 8295 times
http://michaelang.com - Art / Engineering
