When entering a sketch - is it possible to make the view not only orientate itself to the sketch plane (ViewSketch https://wiki.freecadweb.org/Sketcher_ViewSketch), but also enable section view (ViewSection https://wiki.freecadweb.org/Sketcher_ViewSection)?
If not - this would be a very useful setting (or default mode)!
Section view by default in sketch mode?
Re: Section view by default in sketch mode?
Sorry, I had this tab open for a pretty long time.drucken wrote: ↑Thu Mar 25, 2021 11:13 am When entering a sketch - is it possible to make the view not only orientate itself to the sketch plane (ViewSketch https://wiki.freecadweb.org/Sketcher_ViewSketch), but also enable section view (ViewSection https://wiki.freecadweb.org/Sketcher_ViewSection)?
It's not possible, but it will be if/when this PR is merged.
Please leave more tabs open for a long time if that yields such results
Just wanted to inform the OP that I have issues with using Section view and don't use it any more; I made some model errors that I believe would have been caught if I could have seen thru the whole model. I instead use a macro to set global visibility, this way I can see near and far for alignments or misalignments. Don't get me wrong, section view works but I think any time you hide lines or parts of objects there is an increased chance of error.
My 2 cents....
My 2 cents....
If you want to try a different (from the default) modeling design approach, here is a macro that changes global visibility with a button click; Vis=100 would be the FreeCAD default and objects will appear solid. This can make sketching and sketch viewing much easier IMO. You can also goto Preferences-Sketcher-Display-"Hide all objects that depend on the sketch" and uncheck it, then click "Apply to existing sketches", this will keep all the solids in your sketch visible.
I use this method daily.
The "Res" buttons can fix those chunky holes and make them smooth round. This is useful for better visualizing if you are sketching up to a hole.
- Vision1_simple.FCMacro
- (5.2 KiB) Downloaded 23 times
- Vision1.5.JPG (14.35 KiB) Viewed 1066 times
PR merged today as version 24782 (thx abdullah).openBrain wrote: ↑Sun Apr 18, 2021 6:18 pm It's not possible, but it will be if/when this PR is merged.
Just built against that an tried it...sweet!openBrain wrote: ↑Sat Apr 24, 2021 4:38 pmPR merged today as version 24782 (thx abdullah).openBrain wrote: ↑Sun Apr 18, 2021 6:18 pm It's not possible, but it will be if/when this PR is merged.
Thanks, all.
I couldn't test it yet, so my thanks are premature, but due to forum noise I will probably be unable to find this topic, when it gets into the next precompiled package.
In Sketcher when using Section view the nearside stuff is hidden, could we instead (or by option) hide the faces and keep the lines visible, this would give better nearside visibility to verify alignment?
Farside is the part we see.
Nearside is the part that is hidden.
