FCCircularText Issues
leoheck
Post by leoheck »
I am trying to use this FCCircularText macro, it is a really cool macro to help to address this problem.
I just want to report some issues on version 0.19 2021/03/15
1. The window is not showing texts completely and the buttons are not sized properly.
2. Starting/Ending angles cannot be float numbers.
3. After clicking on Run, it is resetting the fields, this is not good when you are experimenting with different designs.
4. FCCircularText is so bad when looking on Plugins Manager. Plugins manager doesn't have any way to search for plugin names on that list. Having FC in front of the Plugin Name makes it hard to find on that list. Is it possible to rename it to "Circular Text" only?
I am attaching a picture of it to discuss how we could improve this.
OS: Ubuntu 20.04.2 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.
Branch: unknown
Hash: e8566f22bbeb0b7204e3c45519d0963e8881100b
Python version: 3.8.5
Qt version: 5.12.8
OCC version: 7.5.1
M4x
Re: FCCircularText Issues
Post by M4x »
Regarding the search, you could've a look at the wiki to look through the macros.
GeneFC
Post by GeneFC »
It is best to contact the author, Mario52, to discuss any suggestions for the macro. Or at least ping him on the forum.
Nobody else is in a good position to help. Unlike core elements of FreeCAD the macros are completely controlled by the authors as long as the macros follow basic rules for working with FreeCAD.
Gene
M4x
Post by M4x »
mario52 wrote: Ping
mario52
Post by mario52 »
hi
try the latest version 0.20 - 2021/04/05
leoheck wrote: Thu Mar 25, 2021 3:13 pm 1. The window is not showing texts completely and the buttons are not sized properly.
corrected in latest version also for the all style
leoheck wrote: Thu Mar 25, 2021 3:13 pm 2. Starting/Ending angles cannot be float numbers.
calcul in internal 4 decimal
leoheck wrote: Thu Mar 25, 2021 3:13 pm 3. After clicking on Run, it is resetting the fields, this is not good when you are experimenting with different designs. )
check the Reset checkBox (V0.19 only in Tools > parameter "switchResetFALSE=True" see Wiki)
leoheck wrote: Thu Mar 25, 2021 3:13 pm 4. FCCircularText is so bad when looking on Plugins Manager. Plugins manager doesn't have any way to search for plugin names on that list. Having FC in front of the Plugin Name makes it hard to find on that list. Is it possible to rename it to "Circular Text" only?
maybe lather
for the moment i work for create un "Tampon" here Positif/Negatif
EDIT: 30/06/2021 13:09 Paris : change image for Positif/Negatif tampon
mario
M4x
Post by M4x »
Thank you very much, the last pic looks interesting too!
kajoyner1
Post by kajoyner1 »
I would like to try FCCircularText, but need to know how to load it. I am running FreeCAD 0.19, ver. 24291. When i go to Macro/Macros/User Macros/Macros/Addons, i do not see this one listed. Thanks in advance!
GeneFC
Post by GeneFC »
Check the links in Mario's signature line above. The macros can be found in github.
Gene
It must be installed with the AddonManager before you can use it.
kajoyner1
Post by kajoyner1 »
I am running FreeCAD 0.19, version 24291 on Windows 10.
This is what I have done:
I went to the Macro FCCircularText - FreeCAD Wiki site: (https://wiki.freecadweb.org/Macro_FCCir ... t#Script_2).
From that page, I went to GitHub and downloaded the .zip file and unzipped it to the FreeCAD Macros folder. It had a long name composed of seemingly random characters. I re-named it: FCCircularText.FCMacro. I also copied the CircularText icon to that same folder.
Per chrisb 's comment above, when I go to AddonManager, I do not see it listed.
When I go to the FreeCAD dropdown menu: Macro/Macros, it shows up under User Macros. When I click on it the options on the right hand side are enabled. When I went to Addons... at the bottom right, I did not find it listed under Macros. Going back to the previous screen, I wasn't sure which to click and decided on "Execute", but can't see that anything has happened. My question: What do I do now?
