LinkDaily branch 3D view experimental renderer
-alex-
Postby -alex- » Thu Apr 01, 2021 10:35 pm
OS: Debian GNU/Linux 10 (buster) (LXDE/LXDE-pi)
Version: 0.19.27742 (Git)
Build type: Unknown
Branch: LinkStage3
Hash: 0a157a307c91d241a370cdda6d8f0471b7c48915
Python version: 3.7.3
Qt version: 5.11.3
Locale: French/France (fr_FR)
realthunder wrote:ping
I've read you introduced an experimental 3D view renderer in Linkstage3 2021-03-28 release: https://github.com/realthunder/FreeCAD_ ... 3/releases
The Daily branch introduces an experimental renderer that bypasses Coin3D and do its own rendering. It renders much faster than Coin3D for complex and deep assembly hierarchies (works for assembly STEP imports). You can enabled it in Preference -> Display -> Render cache -> Experimental. The renderer does not yet work with nodes that uses texture, e.g. text labels in Draft.
I have sync your branch yesterday but I can't find this setting in Preferences/Display menu though. Does I get you wrong?
Does this renderer need some additional libraries?
I would like so much to test such alternative to Coin3D on my Raspberry PI4 system :)
realthunder
Re: Linkstage3 branch 3D view experimental renderer
Postby realthunder » Thu Apr 01, 2021 11:07 pm
-alex- wrote: Thu Apr 01, 2021 10:35 pm I have sync your branch yesterday but I can't find this setting in Preferences/Display menu though. Does I get you wrong?
The renderer is in the LinkDaily branch. Once compiled, you can enable it in Preference -> Display -> Render cache -> Experimental. Right now, the renderer is just a proof of concept. It takes the Coin3D scene graph, and build its own render list sorted by material just like most of the real time renderer out there, and uses OpenGL to render it. In the future, the OpenGL part will be replaced by other library for other fancy graphical effects.
-alex-
Postby -alex- » Fri Apr 02, 2021 6:39 am
realthunder wrote: Thu Apr 01, 2021 11:07 pm The renderer is in the LinkDaily branch. Once compiled, you can enable it in Preference -> Display -> Render cache -> Experimental.
I've read that but I had not fully understood. Now I get it, So now I have to compile your linkdaily branch, thank you.
BTW I'm also gonna change my other post I've made about your toponaming algorythm here
-alex-
Postby -alex- » Thu Apr 08, 2021 5:22 pm
realthunder wrote: Thu Apr 01, 2021 11:07 pm Right now, the renderer is just a proof of concept. It takes the Coin3D scene graph, and build its own render list sorted by material just like most of the real time renderer out there, and uses OpenGL to render it. In the future, the OpenGL part will be replaced by other library for other fancy graphical effects.
If I get your meaning, you mean OpenGL rendering from Coin3D could be replaced by Vulkan rendering for eg? Right?
The Coin3D scene graph could be used by Vulkan lib thanks to your experimental renderer?
realthunder
Postby realthunder » Mon Apr 12, 2021 6:41 am
-alex- wrote: Thu Apr 08, 2021 5:22 pm If I get your meaning, you mean OpenGL rendering from Coin3D could be replaced by Vulkan rendering for eg? Right?
Yes, sort of. I intend to those library (e.g. DiligentEngine) that can abstract away the actual graphics library calls, such as OpenGL, Direct3D, Vulkan, etc.
-alex-
Postby -alex- » Mon Apr 12, 2021 7:07 am
realthunder wrote: Mon Apr 12, 2021 6:41 am Yes, sort of. I intend to those library (e.g. DiligentEngine)
Wow, seems very promising 8-)
Furthermore Vulkan 1.0 is available on Raspberry PI4 board, I would be so happy to try it with FC to see how much it could speed up the 3D view framerate and if that will fix some segfault crashs :-)
Keep forward! :-D
-alex-
Postby -alex- » Thu May 13, 2021 6:59 pm
Hi, I've compiled your LinkDaily branch on my Raspberry PI4. Experimental render cache works fine :)
But it works slowly compare with master branch, maybe there is some reason which explain this statement, I don't know.
I performed some test with an array of 7290 Part_Cube with transparency 90% :
cube_array.FCStd
(205.16 KiB) Downloaded 3 times
While rotating the model in 3D view I get:
- with master branch render cache=auto: -> about 12fps
- with LinkDaily branch render cache=auto: -> about 4.5fps
- with LinkDaily branch render cache=experimental: -> about 6fps
I understand that's a work in progress, is it the intended result at this stage? Or I did something wrong?
Version: 0.19.27927 (Git)
Build type: Unknown
Branch: LinkDaily
Hash: c9afa55c7adb347b2e903d818956843ef0f5a978
Qt version: 5.11.3
realthunder
Re: LinkDaily branch 3D view experimental renderer
Postby realthunder » Fri May 14, 2021 1:50 am
Hmm... maybe you didn't enabled VBO? I just tested the file. Yes, it does seem to be slower comparing upstream with 'Auto' caching, but 'Experimental' has the same performance. The difference between 'Auto' and upstream is in how transparency is handled. In my branch the triangle sorting is handled in FreeCAD instead of Coin3D to workaround problem of rendering artifacts of transparent faces at certain angle. But the performance should be about the same. I'll investigate later.
The reason I decide to implement my own render caching is two fold. For one, with customized caching, it is now possible to handle rendering entirely in my own code, which makes it much easier to use other rendering library as mentioned in my previous post. Second, the Coin3D render caching is not good at handling hierarchies, more specifically, it is not good at handling cache changes in the hierarchy. If the cache is always clean, then the performance is good, but if it becomes dirty or got disabled (e.g. because of selection highlight), the performance will drop because it has to traverse the hierarchy for rendering. My experimental renderer caches the geometries in a flattened data structure, so it will always have the same rendering performance regardless of changes in the scene hierarchy.
To demonstrate the problem, you can select one face in the cube array (or just pre-select a face and spin the 3D view) and see huge drop of rendering performance in upstream. This is because Coin3D render cache is disable if there is element selection in transparent object. This problem can be solved by changing how selection highlight is rendered. In my branch with `Auto` render caching, you have the option to render pre selection highlight on top. And this makes it possible to keep using the Coin3D render cache. However, with other more advanced effects, such trick won't be so effective. For example, in my branch, with 'Selection on top' enabled, the selected object will become transparent and rendered on top with alternative hidden line style, all of which affects the rendering performance if using Coin3D. But with my 'experimental' caching, the performance is the same.
phpBB [video]
https://youtu.be/DIAvTmqjZ9Q
Zolko's lego house is a more suitable files for benchmarking, as it contains deep hierarchies. Another one is this, which has large amount of Link instances to relatively simple geometries with hierarchies. I got only 5fps for rendering the later model using 'experimental' renderer. I expect this type of scene to perform a lot better if using shader with OpenGL instancing.
