Thank you for this marvelous system.
OS: Windows 10 Version 2004
Version: 0.19.24276 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
I noticed a difference between v18 and v19, couldn't find any "update differences" info but maybe just don't know where to look. Here's what happens: In V18, I did a lot of Trial and Error (Poke and Hope, if you prefer), trying to determine whether this Pipe goes clear through the outer rim of this Bowl, or whether the outer rim goes through the Pipe, and I have to mechanically drill it out after Printing. (I tried making the Pipe a separate Body, tried Pad-then-pocket, tried Boolean Cut of 2 Part Cylinders, tried like this method shown here. Each one had its own set of troubles, like only one Body at-a-time can go to TechDraw views, so I did Boolean Fuse, which can lead to wildly divergent results.) Often, I open 2 or more Documents at-a-time, to refer to their Sketches in creating the working Document, like this:
Notice only one Document at-a-time appears in Tree View:
In V19, both Documents appear incorporated in Tree View:
and now I'm ascared to change either one, for fear of messing up the other. Are the Documents accidently incorporated, or is this a newer, better Tree View that lets you see all but does not mix them together (that's my assumption but I like to know for sure.)?
And the 2nd quirk, when I first generated the Polar Array on the Bowl's flange, I just typed in '5' for occurrences, and it returned and error: 'recursive calling of recompute', but when I <ctrl>-z out of everything, then use the up-arrow to click up 2, 3, 4, then 5 occurrences, each iteration displayed the corresponding number of occurrences, and successfully created 5.
Thank you for your kind attention.
