Unit mismatch in Expression
edwilliams16
Postby edwilliams16 » Tue Apr 06, 2021 6:16 pm
OS: macOS High Sierra (10.13)
Version: 0.19.24276 (Git)
Branch: (HEAD detached at 0.19.1)
Python version: 3.8.8
Qt version: 5.12.9
OCC version: 7.4.0
Locale: C/Default (C)
I have two cubes (primitives from Mesh Design) and am attempting to tie them together with an Expression.
Cube.Height + Cube.Placement.Base.z
This fails with a unit mismatch. But it shouldn't! Both quantities are mm.
The same expression works within a Part Design primitive Box.
Roy_043
Re: Unit mismatch in Expression
Postby Roy_043 » Tue Apr 06, 2021 6:34 pm
edwilliams16
Postby edwilliams16 » Tue Apr 06, 2021 7:30 pm
I saw no discussion of a work-around, but I found one
Cube.Placement.Base.z / 1mm + Cube.Height
The result shows in mm in the editor and works correctly. This of course makes no sense, since the units of Cube.Placement.Base.z certainly aren't mm^2. I doubt this works with imperial units, but that's another problem.
Before the OP, I had tried
Cube.Placement.Base.z  + Cube.Height*1mm
which makes a bit more sense, but that didn't work.
Roy_043
Postby Roy_043 » Tue Apr 06, 2021 7:51 pm
Which of the 2 solutions works depends on the target property. The 1st will work for the Height of another mesh cube (which is unit-less), the 2nd will work for the Z coordinate (which does have units) for example.
edwilliams16
Postby edwilliams16 » Tue Apr 06, 2021 8:09 pm
That would make sense, but isn't true.
For setting the height or the z-coordinate without reported errors, both require the
Cube.Placement.Base.z / 1mm + Cube.Length
form.
It's a confusing mess. The code has no consistent view of the units here.
unitmismatch.FCStd
(223.53 KiB) Downloaded 2 times
Roy_043
Postby Roy_043 » Wed Apr 07, 2021 8:19 am
For the Z coordinate both solutions work here:
OS: Windows 8.1 (6.3)
Version: 0.19.24219 (Git)
Hash: 8c26baebab320b8c1c3279bc8eb34a1eb6c7a363
Python version: 3.6.8
Qt version: 5.12.1
Version: 0.20.24587 (Git)
Hash: 1f62d4666102d8efd4d8f3ba58a1037456a3bcfb
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Postby chrisb » Wed Apr 07, 2021 8:57 am
If I set the length of a mesh cube I get these results
- set to Cube.Placement.Base.z + Cube.Length is not allowed, with the message of a unit misatch
- set to Cube.Placement.Base.z + Cube.Length * 1mm is accepted, but shows the message "(Warning: unit discarded)"
Setting the Z component of the placement works with Cube.Placement.Base.z + Cube.Length * 1mm.
This means that the placement has units, while the dimensions have not. As far as I know at least the stl format doesn't have units either.
OS: macOS 10.16
Version: 0.20.24612 (Git)
Hash: f525904c1be10a0f55aa3502151c2c55e5054259
Python version: 3.9.2
Qt version: 5.12.9
OCC version: 7.5.1
Site Admin
Postby wmayer » Wed Apr 07, 2021 10:47 am
No, they aren't. All mesh primitives still use raw float properties and not quantities. You can easily see this fact in the property editor when you create e.g. a mesh cube. The values of Length, Width and Height are displayed as 10.00 and not 10.00 mm.
It works! When you set the expression for the Length property
then this error is shown Quantity::operator +(): Unit mismatch in plus operation
and the OK button is greyed out.
When you change the expression to
then a warning is shown: 10.00mm (Warning: unit discarded)
but the OK button is active in order to accept it. The warning makes perfectly sense because the expression has a unit but the Length property is dimensionless.
The code works correctly. The point is that the code for the mesh primitives is very old (> 15 years). So it was written long before we implemented the unit framework but we never moved the mesh primitives from using raw float properties to quantity properties.
edwilliams16
Postby edwilliams16 » Wed Apr 07, 2021 6:06 pm
Snip macro screenshot-59b6dc.png (11.19 KiB) Viewed 101 times
OK. I understand things now. What threw me was the above which shows a dimensionless quantity as mm. Looking more carefully, when you actually enter the quantity it shows as "185", then on closing the dialog it shows as 185 mm. This is obviously trying to be helpful, defaulting the dimensionless quantity to the default unit, but it did confuse me.
Site Admin
Postby wmayer » Thu Apr 08, 2021 12:17 pm
Exactly. The property type PropertyPlacement has a Base::Placement as data type and that consists of a Base::Rotation (that is implemented as a quaternion) and a Base::Vector3d. The class components of the Rotation and Vector3d are all doubles.
So, actually all values of a PropertyPlacement are dimensionless but for the expression engine (see PropertyPlacement::getPathValue) and the property editor (see PropertyPlacementItem) a dimension is shown to the user.
